synthetic Rotella 5W-40 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 10 (permalink) Old 04-08-2011, 11:17 AM Thread Starter
This is a segway from DIRTRACK650's 11K rpm thread...
To cut down on the coffee grinder noise, I switched to synthetic Rotella 5W-40 three oil changes ago. While it helped, I still have it. How bout you guys...any have same experience?
VoIPDoc is offline
post #2 of 10 (permalink) Old 04-08-2011, 11:49 AM
I was gonna try Rotella T6 5w40 next right now Im just running the 15w40 Rotella....... I usually use Amsoil in everything I own but lookin to save a little money you sure its not your ACCT's your hearing switch to manual CCT's...... or maybe your balancer?
qweesy is offline
post #3 of 10 (permalink) Old 04-08-2011, 01:21 PM Thread Starter
Yes, I'm sure. Thx
VoIPDoc is offline
post #4 of 10 (permalink) Old 04-08-2011, 01:59 PM
DelmarvaBiker
DelmarvaBiker's Avatar
Send a message via Yahoo to DelmarvaBiker
Last December I switched from the 20w-50 that the previous owner had used, in my bike, to the Rotella synthetic 5w40. While it did not eliminate the coffee grinding it has greatly reduced it.
2003 VN750
DelmarvaBiker is offline
post #5 of 10 (permalink) Old 04-08-2011, 05:29 PM
Bronson's Avatar
The coffee grinder is alot less common, but I can still produce it on a cold engine. It's alot better than before however, and I really like the protection and clean internals of the engine with the Rotella.
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #6 of 10 (permalink) Old 04-09-2011, 01:02 PM
cglennon's Avatar
All previous oil changes on my '06 have been done by the dealer and I've always had coffee grinder to some extent. On one of those previous dealer oil changes I paid for the full synthetic (Castrol I believe). It greatly reduced the coffee grinder, but did not eliminated it completely. The full synthetic also seem to have much smoother shifting, but it was expensive and overall didn't think the added prices was worth it.
I've heard good things about Rotella's T6 from this forum and others (it is very popular with bikers of all makes and models), and wanted to try it. So, I recently did my own oil change with Rotella T6 to see first hand if it would solve the coffee grinder issue. Prices was right at $18/gallon and $6 for a Bosch 3323 oil filter making the total half what the dealer is charging. However, I had similar coffee grinder results as with the dealer's synthetic oil; greatly reduced, but not eliminated. I was hoping that it would improve over time, but perhaps not according to your results. However, for the price I think it is a better deal, for me, over the dealer oil change.
Side note: I used a Bosch 3323 oil filter and the oil light goes out much faster than it did after a dealer oil change (using an OEM oil filter). I don't know if that is due to the Bosch oil filter (i.e., larger capacity, better flow, anti drain back valve or some combination), the oil (5w being a bit thinner when cold) or both. Either way, I like it.
Chris Glennon - Portland, OR
cglennon is online now
post #7 of 10 (permalink) Old 04-09-2011, 05:09 PM
KidChaos's Avatar
Clarification please---
Coffee grinder sound is a slightly high pitch, but not quite squealing, kinda gritty sound coming from the right side? of the engine during high RPMs (above idle). This is just my guess because I just noticed this sound.
If this is an accurate description, what are the cause(s) or is that uncertain?
Finally, Rotella synthetic helps reduce it, but conventional doesn't?
KidChaos is offline
post #8 of 10 (permalink) Old 04-09-2011, 11:32 PM
'03 VN750 "Rosie"
bstew7890's Avatar
I read that the problem is caused by cold oil trapped in the clutch basket keeping the plates from connecting smoothly. Once the oil warms and works its way out of the clutch it starts working right.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #9 of 10 (permalink) Old 04-10-2011, 12:10 AM
'03 VN750 "Rosie"
bstew7890's Avatar
I read on an oil web site something that has kept me from buying 5w40. Multi-viscosity oil is made by taking a base oil and adding a thickening agent that's heat-activated. It's a molecule that coils up small at room temperature and then uncoils when heated. A bottle of 5w40 is really the same base oil as a bottle of 5w30 but with a higher percentage of thickening agent. 10w40 has less thickening agent (about half) than 5w40 because it is a thicker base oil to begin with. 20w50 has the least percentage of thickener. Here's my concern: the thickening agent is not a lubricant, it just thickens your oil when hot to slow down the flow and help it stick to parts just a little bit longer. Am I worrying over nothing? I would rather be putting lubricant in my engine than thickeners. I can learn to live with the coffee grinder.
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
post #10 of 10 (permalink) Old 04-10-2011, 10:54 AM Thread Starter
Makes sense.
Maybe Fergy will chime in....he's the forum oil guru.
VoIPDoc is offline
