Final drives from different bikes? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 04-05-2011, 04:03 PM Thread Starter
Puddles's Avatar
Does anyone know if the final drive from other Kawasakis fit on the VN750? I found some on ebay that look just like the 750's, but they're listed for other bikes, like the ZN700, kz1000, and such. Thanks!
Puddles is offline
post #2 of 8 (permalink) Old 04-05-2011, 04:35 PM
Going with the Ron Ayers "Where does this part fit" search, the Vulcan 700/750 final drive is specific to the Vulcan 700/750.
post #3 of 8 (permalink) Old 04-05-2011, 05:16 PM Thread Starter
Puddles's Avatar
Dang.
Thanks for the info!
Puddles is offline
post #4 of 8 (permalink) Old 04-05-2011, 05:45 PM
This is from memory and it may not be right,But the older eliminator inline 4 wheel will fit our final drive,but I don't know if the gear ratio is the same or if it will bolt up to the swing arm.
post #5 of 8 (permalink) Old 04-15-2011, 02:23 PM
spiral_72's Avatar
I spent hours and days looking for a replacement. The ONLY thing I could find was the Vulcan 1500 rear is "supposed" to fit..... but none of the part numbers are the same and the axle appears to be a different length (which doesn't look good in itself).
Neither could I find a aftermarket ring and pinion...... so it looks like a complete custom job, or change the tire size.
I hope that helps. I'm not saying a replacement doesn't exist.... I just couldn't find it outside of buying some from the junkyard and trial fitting each one.
I just wanted to cruise down the interstate at 3500 RPM
spiral_72 is offline
post #6 of 8 (permalink) Old 04-16-2011, 03:27 AM
the "old" vn1500 will interchange with a lot of work... you need to make axle spacers, and a few other parts...
post #7 of 8 (permalink) Old 04-16-2011, 09:54 AM
KidChaos's Avatar
Spiral, I got a line on a Final Drive I was going to buy, but mine is better than I originally thought. Shoot me a PM and I will set you up with my seller. He want $200 for the Final Drive and Driveshaft Coupling. I saw a picture of the Final Drive and splines look great. Haven't seen a pic of the coupling yet.
Good Luck
KidChaos is offline
post #8 of 8 (permalink) Old 04-17-2011, 08:15 AM
there is a vn750 final drive right now for 100 bucks on fleebay
