Why it won't carry a load? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 12 (permalink) Old 04-04-2011, 03:26 PM Thread Starter
Cool Why it won't carry a load?
Hello all i'm a newbie to the forum, but have been looking over the forum for the last year. I gooten alot of help from this forum during that time, everything from removing the engine to replacing the stator.
The problem i'm having now is that my bike want carry a load. i've tried everthing i can think. While the bike is sitting on centerstand i can shift into every gear with no problem, rear wheel spin, and stop when i apply the breaks.
But as soon as i take it off the stand i get no aclleration the bike will not.
Is their anyone that can help me this problem Thanks
Bone is offline
post #2 of 12 (permalink) Old 04-04-2011, 03:43 PM
dynajim's Avatar
Neutral safety switch bad?
'94 VN 750 17k mi. Aqua, Memphis shade.
Acquired 2/2011
Oiled
Tank cleaned
New Fork seals
Idle jets-RT-3.0, Lft-2.5 turns
Sea Foamed
New Batt for grins
Stupid hose in the rt ear found and fixed
Major clutch adj.
New Petcock
New Shimko tires
De-goated before I got it.
Iridium plugs
YEA! New choke cable!!
Gonna do the Spline Lube soon(Chged tires before I found this site)
Replacement for my FXDWGI
Why didn't I find these before I spent $22 grand!!
dynajim is offline
post #3 of 12 (permalink) Old 04-04-2011, 03:56 PM
I don't think so since it will run thru the gears on the center stand. It's once the bike is on the ground & trying to move. "Under a Load". I'm stumped. I don't suppose it could be clutch related?
post #4 of 12 (permalink) Old 04-04-2011, 04:16 PM
Gemguy's Avatar
on the center stand it doesn't need as much fuel as it does under load. running through the gears on the stand it's basically sucking as much as at idle. On the wheels it needs more.
Has this bike been standing for a long time with the same gas in it? Could the lines be clogged?
~VROC~ # 389
Gemguy is offline
post #5 of 12 (permalink) Old 04-04-2011, 04:27 PM Thread Starter
Well the bike has been sitting through the winter. During this time i replaced the stator, changed the fluids,checed and rechecked everything esle. this is a problem i can't figure out.
Bone is offline
post #6 of 12 (permalink) Old 04-04-2011, 04:27 PM
clock152's Avatar
yes.. does the engine rev while on the ground when you give it gas??.. have you checked the splines?
clock152 is offline
post #7 of 12 (permalink) Old 04-04-2011, 04:29 PM Thread Starter
i will be trying all sugestion until i get it repaired!!
Bone is offline
post #8 of 12 (permalink) Old 04-04-2011, 04:31 PM Thread Starter
yes the engine does rev, i have not checked the spindle as of yet.Biut that will be my next thing to do
Bone is offline
post #9 of 12 (permalink) Old 04-04-2011, 05:29 PM
clock152's Avatar
is there any noise while you have it in gear and on the stand around the swing arm area?
clock152 is offline
post #10 of 12 (permalink) Old 04-04-2011, 06:00 PM
It takes very little friction to spin the rear tire with no resistance while it is sitting on the center stand.
My impression is it must be either the clutch is worn out/not adjusted properly, or the rear splines are worn out.
If either one of those is true, there should be noise from slippage or grinding.
