Stripped threads- gear oil drain - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 01-17-2011, 02:17 PM Thread Starter
dark cloud's Avatar
Well, I finished my spline lube yesterday. That went great, following Fergy's tutorial. Since I was on a roll, I decided to change the gear oil. Now I can't seem to get the plug to fully tighten, and judging from the metallic fragments I stripped the threads on the pan.
I tried to search the forum, but didn't find what I was looking for. Any ideas?
Dark Cloud
2006 Vulcan 750
dark cloud is offline
post #2 of 6 (permalink) Old 01-17-2011, 03:18 PM
Originally Posted by dark cloud View Post
Well, I finished my spline lube yesterday. That went great, following Fergy's tutorial. Since I was on a roll, I decided to change the gear oil. Now I can't seem to get the plug to fully tighten, and judging from the metallic fragments I stripped the threads on the pan.I tried to search the forum, but didn't find what I was looking for. Any ideas?
I assume you mean the drain plug has stripped the threads on the final drive.
The cheap DIYer in me recommends that you let the unit drain until no more oil drips out, then clean it well with brake cleaner or electrical contact cleaner. Try applying some silicone around the sealing rim on the circumference of the plug when you snug it up as much as possible. You might need to smear a little more silicone on the surface after the plug is installed if it continues to leak.
IMO this is worth a try, to save the price of a new or used final drive.
post #3 of 6 (permalink) Old 01-17-2011, 08:08 PM
flitecontrol's Avatar
I've used this, and it worked for me: http://www.midwayusa.com/viewproduct...tnumber=986916 You may be able to find it locally.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #4 of 6 (permalink) Old 01-19-2011, 12:37 PM Thread Starter
dark cloud's Avatar
Thanks for the above ideas. My car mechanic suggested getting a slightly larger plug with the same type threads. I'm going to try that and I'll let you know how it works.
Dark Cloud
2006 Vulcan 750
post #5 of 6 (permalink) Old 01-19-2011, 02:06 PM
I think this will work good. Just make sure the bolt is the same lenght. If there are any shavings it will not hurt cause it is aluminum. It soft enough that it will not hurt the steel gears.
post #6 of 6 (permalink) Old 01-19-2011, 07:09 PM
I`ve heard of oversize self-tapping drain plugs for the crankcase, but never thought of trying something similar on the bike`s final drive, when I wrote the first post. That`s probably the best idea for the stripped threads I`ve seen here.
