Spline Lube job - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 01-10-2011, 03:29 PM Thread Starter
marinecorpsvet's Avatar
Spline Lube job
Got a 2006 750 and I'm gonna be taking another long trip on it this spring, about 4000 miles. Gonna try the spline lube job myself, just to make sure before I leave. Anyone out there give me the proper parts to have and a good place to order from?
I think we gotta have 2 rubber seals and the moly....and grab your rosary and pray for me....
Riggs
2006 750 VN
Vance and Hines Pipes
Crash Bar with Pegs
Mike's bags
Mustang seat
"I dont give a crap how much you paid for your ride,
you wanna go or not?"
marinecorpsvet is offline
post #2 of 7 (permalink) Old 01-10-2011, 03:45 PM
n2omike's Avatar
Here's the best deal (with shipping) that I've found. I purchased it from the same place, and had very fast shipping.
http://cgi.ebay.com/ebaymotors/Genui...Q5fAccessories
My bike is an 05 with 5k miles, and the splines were already lubed from the factory. (maybe they finally started doing it consistently in the last couple years???)
Anyway, all I needed was the grease. The o-ring was still in good shape. I'd say, with yours being an 06, you shouldn't need a new o-ring... but you never know. An old toothbrush is good for brushing the grease down into the splines. Don't forget to do the front splines as well, and use the correct special 60% moly spline grease in the link. Regular grease will NOT do.
Good Luck!
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front Tire
6k miles
PW50, XR50, TTR90, XR100, DT175 (2-smoker), CRF230F, XR250R (dual sported), XR400R 4 KIDS, LOL!
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
post #3 of 7 (permalink) Old 01-10-2011, 04:04 PM
fergy's Avatar
A lot of what you'll need is listed in the procedure in my sig. Wouldn't hurt to have the o-ring just in case, and use the Honda Moly 60. Good luck!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 7 (permalink) Old 01-10-2011, 06:09 PM
flitecontrol's Avatar
You can get a whole box of O-rings from Lowes cheaper than you can buy one O-ring from Kawasaki!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 7 (permalink) Old 01-10-2011, 06:09 PM
KIMMERLING's Avatar
You will be set if you do what these gentlemen said. You will ride with security of knowing your splines are lubed and spirits of riders that have come before you will ride with you and ensure your safe and enjoyable trip. Thanks for your service!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #6 of 7 (permalink) Old 01-10-2011, 06:43 PM
Arrow spline lube
Put the bike up on the center stsnd and a 2x6 remove the shocks and disconnect the brake rod connection. use a small jack to adjust the bike to the correct height to remove the rear axle and not hit the exhaust pipes.
The o ring was perfect and only new lube and a new cotter pin was needed. half day job.
good luck
Bob
hegman is offline
post #7 of 7 (permalink) Old 01-10-2011, 08:24 PM
You can tie the center stand to the front tire to ensure that you don't push the bike off the stand.
