Clutch shot - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 15 (permalink) Old 05-25-2006, 10:37 PM Thread Starter
DMAG's Avatar
Clutch shot
Rode Priscilla into work today...her first real ride this year.
When first starting out (cold) the clutch was "ok"....but once I reached highway speeds she would hardly hold 65 mph without the clutch slipping and grabbing suddenly. Once I got off the parkway, it slipped horribly in every gear.
Kinda embarassing since my V&H's REALLY accentuate the high RPMs when it slipped.
Time for a new clutch I guess.
Opinions on a new clutch? Easy job?
Anthony
1985 VN700 (Priscilla) Sold
Helpful Links -->>
Search | Vulcan Verses | VN750 Gallery | VN750 Items on Ebay | Link to VN750.com
DMAG is offline
post #2 of 15 (permalink) Old 05-26-2006, 03:24 AM
I thought I was going to have to replace my clutch, but it was just glazed, the job itself is probly the most straight forward job I have ever seen/read a few bolts and its done!, the enging can stay in frame, and I was also told the exhaust can even stay in place, but I would remove it anyway ~clutch side~, good luck.
Rick_in_WA is offline
post #3 of 15 (permalink) Old 05-26-2006, 08:56 AM
Search Goddess
Dianna's Avatar
From the Vulcan Verses here
https://www.vn750.com/forum/showthread.php?t=1094
Pretty easy to do, just remember to adjust your clutch afterwards since there will be a difference.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 15 (permalink) Old 05-26-2006, 10:57 AM
Loran in Npvl IL's Avatar
How many miles on Priscilla? Double check the clutch adjustment (there are 2 different places to adjust the clutch). But if you smoked the clutch then I think even after adjusting, the clutch can't be saved.
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #5 of 15 (permalink) Old 05-26-2006, 11:48 AM Thread Starter
DMAG's Avatar
Speedo says 27,000....but who knows? I had to replace the speedo cable when I got her so previous owner could've rode many miles without recording the miles. (I bought it off someone who bought it off someone, etc... no history)
Thanks for the link Dianna. Looks to be pretty easy. I have a new clutch cable as well...might as well do 'em both now.
Anthony
Helpful Links -->>
DMAG is offline
post #6 of 15 (permalink) Old 05-28-2006, 10:37 PM Thread Starter
DMAG's Avatar
I read through the Verses regarding the clutches and saw a couple of recommendations. Anyone have any of their own recommendations on what clutch to buy? Also, can I just buy frictions or do I have to replace the prings as well?
Thanks!
Anthony
Helpful Links -->>
DMAG is offline
post #7 of 15 (permalink) Old 05-28-2006, 11:00 PM
count on adding new springs into the mix, as the stock ones are not near as good as the aftermarket ones
post #8 of 15 (permalink) Old 05-29-2006, 12:12 AM
Search Goddess
Dianna's Avatar
The EBC Kevlar clutch KIT: http://tinyurl.com/e3x6h includes the friction plates and springs.
Kevlar paper-lined plate set, complete with heavy-duty clutch springs
Use in production-based race bikes and heavy sport bikes
SRC kits have higher heat resistance and longer plate life
SRC kits have a more aggressive/faster clutch takeup than the CK Standard series clutch kits
In fact you get one extra spring. These are the heavier springs then the OEMs.
Should be everything you need as long as the steel plates aren't scored.
The clutch takes 8 friction plates, 7 steel (smooth surface plates) and 5 springs. Steel plates are usually reused.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #9 of 15 (permalink) Old 05-29-2006, 12:37 AM Thread Starter
DMAG's Avatar
Thank you mucho Dianna...Looks like that's what I'm getting. Anyone have experience using this clutch? I understand the frictions are pretty easy to replace. How about the springs?
Anthony
Helpful Links -->>
DMAG is offline
post #10 of 15 (permalink) Old 05-29-2006, 01:10 AM
Search Goddess
Dianna's Avatar
The hardest part of the whole job is cleaning off the old gasket.
The bolts holding the springs break loose fairly easy and I just took them off and put them back on in a star pattern. Once the bolt loosens the springs are easy to get to and pull out. I used a dental pick to get the friction plates and steel plates out. The first few ones you can do with your fingers. As you get deeper into the basket though you will need a pick or something similar to grab the plate and ease it out of the basket.
A friction plate will be the first and last one out.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
