Clunking noise after shifting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 10-18-2010, 12:45 PM Thread Starter
wicker san antonio
My 2002 has 20,000 miles. Lubed splines at 7000 miles.
This morning I have a clunking noise after shifting from 2 to 3rd after I release throttle pressure. Same noise from 3to 4th gear.AS long as I maintain throttle pressure ...no clunk, but when I release presure I get a loud clunk. Almost sounds like a frame member broke.
Thanks for your help.
WWicker, San Antonio
wwicker:
wwicker is offline
post #2 of 8 (permalink) Old 10-18-2010, 03:03 PM
Could be a worn universal joint on the drive shaft.
Your rear splines are due for lube service again too. The recommended service interval is 10K miles.
Check for any looseness between the splines on the final drive pinion shaft and the connector.
post #3 of 8 (permalink) Old 10-19-2010, 10:19 AM
Just to give you something to compare to..
I have about 30mm (1.2 inch) slack at the rear wheel rim when the bike is on center stand and 1st gear on.
pappa is offline
post #4 of 8 (permalink) Old 10-20-2010, 07:46 PM Thread Starter
wicker san antonio
Thanks, Hoss. Pulled the final drive yesterday....splines shot. Had an independant shop mechanic lube the splines 13000 miles back...wonder if he used the Molly 60 like I told him. FYI the local Kawi dealer near Randolph AFB who has an old Kawi wizard in the shop says they shouldn't require re-lubing befoe 20,000 miles. Looks you guys have the gospel regarding spline lubing.
Now searching for a used final drive. New one costs about $1200.
Thanks again for your input.
W Wicker San Antonio
wwicker:
wwicker is offline
post #5 of 8 (permalink) Old 10-20-2010, 07:47 PM Thread Starter
wicker san antonio
Thanks, Pappa. Pulled the final drive yesterday. Splines are shot. Now looking for used final assembly.
wwicker:
wwicker is offline
post #6 of 8 (permalink) Old 10-21-2010, 03:14 AM
KIMMERLING's Avatar
Someone on ebay beat me out of a 2000 final drive with 10,000 miles for 300$ or so ..about a week ago. Keep checking ebay...
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #7 of 8 (permalink) Old 10-21-2010, 09:04 PM Thread Starter
wicker san antonio
I keep looking at my splines on the final drive shaft and I am thinking about just replacing the coupling which has almost no splines left. Showed it to the local Kawi guru today and he thinks it is worth a try. Talking to a salvage dealer today who has a complete assembly for $350 and he said they had tried just replacing the coupling but it never works. Any body there have comment?
wicker/san antonio
wwicker:
wwicker is offline
post #8 of 8 (permalink) Old 10-22-2010, 12:14 AM
flitecontrol's Avatar
If the final drive splines are messed up, they will cause premature wear on a new coupler. But you could get many thousands of miles out of it before it fails, and couplers are cheap. Just hard to say.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
