How to remove the swing arm - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 10-18-2010, 04:22 AM Thread Starter
Can anyone tell me how I can remove the swing arm from the frame.
(and also disconnect the drive shaft joint from the gearbox)
I'm rebuilding a VN750 but I can't find out how the swing arm it is fixed to the frame.
I already took the 14mm nut & 3 allen head screws off both sides but I can't get the arm off.
Attached are some images of the parts I'm talking about.
Thanks.
ID:	3182   Click image for larger version
Vulcan750 is offline
post #2 of 6 (permalink) Old 10-18-2010, 09:51 AM
You see those round circular things in the first picture? They are the swingarm shafts, what it pivots on. There is a threaded hole in each one, you screw the proper sized bolt (and I can't remember the size) into them, and pull them out. the swingarm will then come off, and the driveshaft will disengage from the bevel drive gearcase and come off with it. When you put it back on, you will need to check and adjust the clearance between the swingarm and the frame on the left side. It's good you already have the exhaust system off, as you have to remove most of it to get the swingarm off.
If you are going to be doing a lot of work on this bike, I suggest you either download the service manual from here, or get the Clymer manual. I got the Clymer manual, and found it to be excellent. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 6 (permalink) Old 10-18-2010, 10:00 AM
MANIC MECHANIC
vulcanjoe's Avatar
m5x.7 is the bolt size
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #4 of 6 (permalink) Old 10-19-2010, 04:21 AM Thread Starter
Thanks a lot Jerry.
I assumed the threaded hole was to fit a bold to remove the swing arm shaft. I've tried but couldn't pull it out. I probably have to lift and support the swing arm a bit to get it out.
I've downloaded the Service manual and Clymer Manual from tocmanufacturing.com
Very usefull.
Getting the bike apart isn't that much of a problem. Overhauling the engine, carbs, gear etc and putting it together probably will.. :-) Anyway.. the bike will be rebuild to a custom build bike. At least I know it was running when we started..
You're right VulcanJoe. The bold size is M5.
post #5 of 6 (permalink) Old 04-18-2020, 05:24 AM
where do you download the service manuel
-RustyRatRod
TeamGreen is offline
post #6 of 6 (permalink) Old 04-18-2020, 09:08 AM
Repair Manual: VN750_Vulcan_Service_Manual_Parts_Catalogue
Tags
driveshaft , swing arm
