clutch cable adjustment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 09-05-2010, 11:58 PM Thread Starter
MoBuSee's Avatar
Question clutch cable adjustment
how do you make the cable tighter? i have to let the leaver all the way out to start rolling i need it tight. thanks.
upgrades:
v&h crusers
HID kit blue
coasters
weight reduction
paint
chrome fill tank cover
engine guards
de-badged
progressive shocks
MoBuSee is offline
post #2 of 6 (permalink) Old 09-06-2010, 07:47 AM
Send a message via Yahoo to luigit
follow the cable down from the lever towards the engine and you shall see the adjustment about half way down on the left side of the bike. Its one of those threaded nut doo hickies that take up slack in the cable as you tighten it. kinda like a turnbuckle.
luigit is offline
post #3 of 6 (permalink) Old 09-06-2010, 12:02 PM
Now what
Ironman's Avatar
I've attached a text file that tells how to adjust the clutch.
File Type: txt Clutch lever adjustment - manuals info.txt (4.1 KB, 22 views)
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #4 of 6 (permalink) Old 09-06-2010, 12:35 PM
He needs to loosen it up some. He wants it rolling sooner. Put a little slack in the cable.
post #5 of 6 (permalink) Old 09-07-2010, 10:05 AM Thread Starter
MoBuSee's Avatar
Thanks guys
upgrades:
v&h crusers
HID kit blue
coasters
weight reduction
paint
engine guards
de-badged
progressive shocks
MoBuSee is offline
post #6 of 6 (permalink) Old 09-07-2010, 11:55 AM
Dave
comanche42p's Avatar
niterider,
I did just that this weekend. I put slack in the cable but it didn't make sense moving it that way but it worked. After you posted it made sense. My clutch was way out from previous owner and had gotten worse. The bike would actually jump a little when putting in gear every now and then so I thought it had to be tightened. Put some slack in and readjusted up at the handle to the 3-4mm spec gap and its better all around.
Thanks,
Dave
Have I mentioned this week how much I love this VN750?
comanche42p is offline
