nutral light - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 09-01-2010, 11:41 AM Thread Starter
MoBuSee's Avatar
Question nutral light
my nutral light dosint come on? all the fuses are good and every other light works....and suggestions? thanks
MoBuSee is offline
post #2 of 6 (permalink) Old 09-01-2010, 12:08 PM
Will it come on after starting the bike???
post #3 of 6 (permalink) Old 09-01-2010, 01:52 PM Thread Starter
MoBuSee's Avatar
no it dosint come on period, running or not...
MoBuSee is offline
post #4 of 6 (permalink) Old 09-01-2010, 02:58 PM
Rook's Avatar
If everything else works than...bad bulb? burned wire? Open the pilot box and check it out
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
post #5 of 6 (permalink) Old 09-01-2010, 03:29 PM Thread Starter
MoBuSee's Avatar
:face palm:
MoBuSee is offline
post #6 of 6 (permalink) Old 09-01-2010, 09:14 PM
baldy's Avatar
The connection for the neutral light/safety switch is under the bike. It is a single green wire plugged into a sensor on the motor. Put the bike on the side stand and from the opposite side of the bike look up under at the bottom rear of the motor you will see it. I had to replace the 90 degree bullet connector where it corroded off. If that isn't it, probably the bulb. Make sure the bike is cool where you are around the exhaust pipes. I have a nice scar on my arm from doing this just after shutting the bike off.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
