Did my Spline lube! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 4 (permalink) Old 08-08-2010, 08:59 PM Thread Starter
Keyman's Avatar
Did my Spline lube!
Did my spline lube today with VN750.com's aid of coarse. I will find the author and thank him. But for now thanks to all of you who discuss the things you do here! There certainly is a wealth of information to be had. Mine were not dry but for my peace of mind, it's worth it. Took a couple of hours max.Thanks guys and gals.
"Ruby" 1994 VN750
Purchased May of 2010 w/576 miles
Highway pegs
Cruise control
Rear turn signal relocation
Viking Saddle bags
Saddle bag supports
Chrome "Vulcan" oil cap
Chrome "K" Brake res. cover
Front tire:110/90-19 K673
Back tire:170/80-15 K673
VN750.com Grille Cover
Spline lube 8/8/10
Hot Grips, Heat-Troller & Relay
Irridium plugs DPR7E1X-9
Clock/Volt/Temp
Keyman is offline
post #2 of 4 (permalink) Old 08-08-2010, 09:26 PM
I'd say mine took about 3 hours, I did take one quick trip down to the auto parts store for some brake cleaner to spray everything down before putting on the moly. Probably could have done it in far less than 2 if I didn't take some breaks.
post #3 of 4 (permalink) Old 08-09-2010, 03:09 AM
KIMMERLING's Avatar
brakecleaner
Im no guru but i would use carb clean in this application. Due to its cleaning and lubing ability. Although, one could use brakeclean...it strips all lubricant from whatever and also could affect the oring. This is just a small thing but i try to use brake clean for total cleaning and carb clean when being used near lubricated parts.
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #4 of 4 (permalink) Old 08-09-2010, 10:12 AM
cglennon's Avatar
Non-Chlorinated brake cleaner is now available (make sure it it is listed on the label) that will not harm plastic and rubber. I also use it to clean the mass air flow sensors on my autos.
Chris Glennon - Portland, OR
cglennon is offline
