can't shift out of neutral - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 11 (permalink) Old 06-16-2010, 09:53 PM Thread Starter
sam47's Avatar
Question can't shift out of neutral
My clutch was grabbing 90% in the last 10% of lever travel. I wanted to see if I could make it smoother by performing the clutch adjustment procedure in the Clymer manual. When I was done, I could not shift out of neutral. Tried a few more adjustments but still can't shift out of neutral.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #2 of 11 (permalink) Old 06-16-2010, 09:59 PM
The Professor
lance328's Avatar
Is the engine running when you try to shift?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 11 (permalink) Old 06-16-2010, 11:01 PM Thread Starter
sam47's Avatar
Engine not running.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #4 of 11 (permalink) Old 06-16-2010, 11:11 PM
start it and try it while sitting on the bike.
post #5 of 11 (permalink) Old 06-16-2010, 11:27 PM
IMBoring25's Avatar
Easy check for whether the teeth are lined up or not is to spin the rear wheel and try again.
IMBoring25 is offline
post #6 of 11 (permalink) Old 06-17-2010, 09:15 AM
fergy's Avatar
Yeah, put it on the centerstand and spin the wheel a little, then start it up and see if you can shift it. It won't hurt to spin the wheel a little with it in gear and running. Just don't try to spin it at 60mph or something!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 11 (permalink) Old 06-17-2010, 11:54 AM Thread Starter
sam47's Avatar
Sitting on bike, with bike on center stand, engine running. can shift to first, but can't shift up... stays in neutral.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
post #8 of 11 (permalink) Old 06-17-2010, 12:05 PM
fergy's Avatar
OK, I assume you have let out the clutch and have the wheels turning in first before you pull in the clutch and try to shift to second, right? If you just pull in the clutch and shift into 1st but don't let out the clutch to get the wheels turning, the bike's positive neutral finder isn't supposed to allow you to shift through neutral into 2nd. So, did you let out the clutch and let the wheels spin before shifting into 2nd?
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 11 (permalink) Old 06-17-2010, 12:49 PM
X2 to fergy`s post. The rear wheel has to be turning at a certain minimum speed before the positive NF will allow you to shift into 2nd gear.
post #10 of 11 (permalink) Old 06-18-2010, 04:28 PM Thread Starter
sam47's Avatar
Running the engine and shifting into gear with the bike on the center stand did the trick. Now shifts just fine. Thanks for the help, had no idea that's how it worked.
Sam
2003 VN750
Purchased 4/27/2010
@ 23813 miles
sam47 is offline
Tags
adjusting clutch , shifting stuck in neutral
