Clutch hub mod for coffee grinder noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 05-21-2010, 06:35 PM Thread Starter
chiller's Avatar
This worked great. Easy to do and no-mo-jo in the clutch!
chiller is offline
post #2 of 8 (permalink) Old 05-21-2010, 10:41 PM
What am I missing here...WHAT worked great??
VoIPDoc is offline
post #3 of 8 (permalink) Old 05-21-2010, 11:11 PM
It is a process where holes are drilled into the clutch drum to let oil drain out more readily, I did a search but I could not find it.
post #4 of 8 (permalink) Old 05-22-2010, 02:12 AM
Link to the vulcan verses for description of "coffee grinder symptoms": https://www.vn750.com/forum/showthread.php?t=1091
post #5 of 8 (permalink) Old 05-22-2010, 10:44 AM Thread Starter
chiller's Avatar
Go to the photo gallery in technical photos and on page 3 there is a drawing of the procedure. I marked the clutch hub with a permanent marker and drilled the holes myself with a hand drill. Precision is not a requirement for this simple job. The hardest part is getting the hub nut off and I show how to use a Craftsman strap wrench to hold the hub and remove the nut on page 1.
chiller is offline
post #6 of 8 (permalink) Old 05-22-2010, 11:48 AM
Link to chillers pictures from post above: https://www.vn750.com/photopost/showp...o=2891&cat=503
Here is a picture/diagram from the gallery of the clutch basket and where to drill the holes:
https://www.vn750.com/photopost/showp...to=247&cat=503
post #7 of 8 (permalink) Old 05-23-2010, 10:37 AM Thread Starter
chiller's Avatar
Thanks Hoss!
chiller is offline
post #8 of 8 (permalink) Old 05-27-2010, 10:26 AM
Rook's Avatar
What size socket did you use for the cluch hub nut?
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
