Clutch replacement - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 1Likes
  • 1 Post By VN750Rider/Jerry
post #1 of 8 (permalink) Old 03-23-2020, 03:12 PM Thread Starter
Clutch replacement
Finally got her running and the clutch goes!!! Are there any videos out there for a 750?? All i'v seen are for the 800 or 900. Really need the help.
RG6223 is offline
post #2 of 8 (permalink) Old 03-23-2020, 04:01 PM
NewB to Vulcans
TonyO's Avatar
Not too difficult, access is easy as there is a dedicated cover for it, soak the new plates in oil before installation
'99 Vulcan "Victoria"
TonyO is offline
post #3 of 8 (permalink) Old 03-23-2020, 06:15 PM
If i remember right last plate is offset one notch. And yes soak in oil
firetire2 is offline
post #4 of 8 (permalink) Old 03-23-2020, 06:21 PM
https://www.youtube.com/channel/UCXG...ITj3R4_iL3SGXg
Find the part where he does the clutch, great videos.
Someone posted a list in the past day or so that shows what each part covers.
post #5 of 8 (permalink) Old 03-24-2020, 11:50 AM
I'm a rider
One1's Avatar
If it’s been sitting for that long i doubt the clutch just “went”. Most likely an issue with binding. Check the free play and you didn’t say whether it is stuck closed or open. If it’s not slipping it’s definitely a stuck clutch not a bad one. If it is slipping remove the clutch arm completely and see if it will grab.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #6 of 8 (permalink) Old Yesterday, 05:14 AM
Before you replace your clutch its a good idea to see how the clutch works and the symptoms of a bad clutch. A clutch will have problems and can stop working all together by either slipping, not engaging or not disengaging which is normal when a clutch is going out due to wear or a mechanical failure.
umangiiahp is offline
post #7 of 8 (permalink) Old Yesterday, 04:31 PM
Exactly what do you mean when you say “the clutch goes”?
What is it doing? (Or not doing)
Other than the “coffee grinder” issue these clutches are pretty sturdy.
post #8 of 8 (permalink) Old Yesterday, 09:48 PM
The Vulcan 750 clutch will definitely stick if not used on a regular basis. I let mine sit for about 6 weeks once and like to never got the clutch broke loose. I put the bike on the centerstand, started the engine with it in neutral, pulled in the clutch, revved the engine, and just kept stepping on the rear brake. Killed the engine several times before it finally broke loose.
ubertalldude likes this.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
