Shifter stuck in Neutral - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #21 of 36 (permalink) Old 03-01-2010, 05:51 PM
Havin some fun.........
Strange Paul's Avatar
Same problem just happened to me
Hi everyone. I was riding my 93 a9 the other day when I stopped to resecure some luggage. Pulled in to a car park, re-tied the bag on the back and then went to pull away, but could not get out of neutral (everything else fine). had to get a bike shop to collect the bike and take to their workshop. The culprit was the spring which rests the pawl, it had slipped out of place. A quick push with a screwdriverand it popped back into place. I hope thats it for a while.
I was wondering if any body has had repeat problems with this? And is there anyway of reducing the risk of it happeneing again. I was sort of lucky this time as it happened in town, but would hate for it to happen out in the sticks. I read on other threads about tubes and collars being fitted around the gear shift shaft..is that internally or externally.
Any help appreciated.......ride free.........
Strange Paul is offline
post #22 of 36 (permalink) Old 03-01-2010, 07:38 PM Thread Starter
Joem's Avatar
I got a new spring and no problems since.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #23 of 36 (permalink) Old 03-01-2010, 08:35 PM
IMBoring25's Avatar
New spring and positive results so far here too.
IMBoring25 is offline
post #24 of 36 (permalink) Old 03-02-2010, 01:39 AM
Cool thanks for the feedback. I will order a new spring up and fit as soon as possible. just hope the old one holds until then.
post #25 of 36 (permalink) Old 03-02-2010, 11:26 AM
Glad ya got it fixed pretty easily!
As for the tubes/collars, that's for when the C-clip on the shaft (internal) fails. When this happens, the shift shaft slides in & out more than about 1/8 of an inch.
The collar then keeps the shaft from moving and causing shift problems.
post #26 of 36 (permalink) Old 03-02-2010, 03:31 PM
electrum's Avatar
...and you stick the tube/collar on the outside of the bike between the case and the shifter lever.
the c-clip that comes off is internal, the tube/collar on the outside is a work around so that you don't have to pull the engine and open it up.
96 Vulcan 750
electrum is offline
post #27 of 36 (permalink) Old 03-02-2010, 04:08 PM
Thanks for that info I may well do this fix before anything happens, sorta makes sense, prevention is better than cure........so they say
post #28 of 36 (permalink) Old 03-03-2010, 12:01 PM
The, also, happened to me. with new spring in hand, I found the old one was certainly weak - very weak - compared to the new spring.
Bending the old one made it work OK, but I waited on the parts to get the new spring in place (I had to take the front bevel gear casing off to remove the bottom cover and didn't feel like doing that a second time just to replace a stinking spring...)
OceanTwo is offline
post #29 of 36 (permalink) Old 03-03-2010, 05:45 PM
Thanks for the info. The friend in the bike shop that mine ended up in explained to me what to do if it happens again, but implied that changing the old spring would be quite a task as the cover wont come off fully with the engine in. Is this right? Or am I missing a trick, Is it hard to do? I have some bike skills like I do my own servicing, have had the carbs off, have marbled the machine, fitted new exhausts and lights etc, but I havn't the equipment (or the inclination) to start removing the whole motor. I have rebuilt a z1000 before and although the outcome was great it took a long time and once inside I found lots of extra's that could do with replacing or grinding (valves) etc and I don't want the bike off the road for long as I use it daily.
post #30 of 36 (permalink) Old 03-03-2010, 11:48 PM
IMBoring25's Avatar
With the engine in place, the shaft is too close to the frame rail for the cover to come all the way off. It can be rotated and shifted to an extent, but it's on there and makes a task that would take a good bit of dexterity anyway very demanding in that regard. It also makes it very fiddly to clean the gasket surfaces. I got it done and the new gasket doesn't leak, but it wasn't easy.
