Pawl Issue? - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 14Likes
post #11 of 37 (permalink) Old 06-24-2019, 04:26 PM
I think, maybe, the spring is in place, the internal linkage rod is intact, but the pawl itself is rocked sideways on the shift drum.
Edit: Section 8-20 of the download manual... There's a shift cover with four bolts, but it says to pull the bevel gear first. No need to pull the engine to see the shift pawl. (incorrect info removed by me)
These shifters can't take any abuse at all, stomping the shifter is a definite no-no. Just falling off the kickstand is enough.
And the horizontal movement is fine, retainer clip is apparently in place.
post #12 of 37 (permalink) Old 06-24-2019, 05:23 PM Thread Starter
MSattler's Avatar
So hypothetically speaking, I can jockey the pawl back in the right location?
'08 Road King Classic
'86 VN750 with the following work done to it, after sitting for 19 years:
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #13 of 37 (permalink) Old 06-24-2019, 06:36 PM
Wait, wait ... Stop. I told you wrong about pulling the engine and stator case. Section 8-20 of the download manual... There's a shift cover with four bolts, but it says to pull the bevel gear first. No need to pull the engine to see the shift pawl.
Going back in this thread to edit.
Yes, hopefully. No promises.
In this thread, the original post, it was stuck in neutral and wouldn't shift to 1st, then the internal rod broke later.
https://www.vn750.com/forum/26-trans...irst-gear.html
MSattler likes this.
post #14 of 37 (permalink) Old 06-24-2019, 06:43 PM
There's been a couple of threads starting out like this, but we never got the rest of the story, if I recall.
post #15 of 37 (permalink) Old 06-24-2019, 06:45 PM Thread Starter
MSattler's Avatar
I just changed the oil, but I will see if I can't get it cracked open tonight! I just found this thread, and on the second page, it seems that he was able to put the pin back in it's place (https://www.vn750.com/forum/26-trans...k-neutral.html). I have not bought the Calmyer's (spelling) book yet, but I downloaded the shop manual and the owner's manual. I will see if this information is in one of those two places. Unfortunately, there were no photos taken of the post where this guy fixed the same problem rather easily, with no additional parts.
MSattler is offline
post #16 of 37 (permalink) Old 06-24-2019, 07:01 PM
8-22 in the d'load manual - In the drawing, it shows that odd shaped clip than can slip out of place on the pawl. The clip is stamped spring steel.
8-22 page 154 - part #4
If you're lucky, that clip is out of place.
Move the shifter while touching the shift cover. If you can detect movement in there, the internal shift rod isn't broken.
post #17 of 37 (permalink) Old 06-24-2019, 07:20 PM Thread Starter
MSattler's Avatar
I am going to crack into it tonight (Gott will es) and if so, I will take lots of photos.
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #18 of 37 (permalink) Old 06-24-2019, 09:27 PM Thread Starter
MSattler's Avatar
I donít know what kind of witchcraft was used to get this cover off, but here is my spring.
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #19 of 37 (permalink) Old 06-24-2019, 09:41 PM Thread Starter
MSattler's Avatar
The pawl is like 1mm away from touching the spindle. I did shift a gear then change it back with a screw driver.
John 8:44
REV 2:9
REV 3:9
www.voat.co
MSattler is offline
post #20 of 37 (permalink) Old 06-24-2019, 10:11 PM
Deleted - I was looking at the wrong shaft when I posted here.
