Clutch slipping problems! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 1Likes
post #1 of 15 (permalink) Old 09-15-2018, 11:02 PM Thread Starter
Hey y'all my 2003 vulcan is having some clutch slipping problems. Ive noticed that whenever it happens the clutch lever has a lot more play in it than normal and i cant accelerate. If i try it just slips and revs the engine. So my question is should i lube the cable? If yes, what should i use? Or should i just replace it. If yes please give me your suggestions on cable brands that might hold up better than stock.
Thanks everyone!
raptor093 is offline
post #2 of 15 (permalink) Old 09-16-2018, 12:26 AM
GDI
Can't say for sure, but what you're describing would be consistent with a frayed clutch cable that is just about to give out.
When are you noticing the slipping? Does it matter what gear you're in? Normally when the clutch itself goes bad you don't notice any difference in the lower gears (at first anyway). It'll slip at first in 4th or 5th gear.
If it is just the cable, I would go with stock. That's what I did with mine when the adjuster nut broke. Only reason I'd go with aftermarket is if I happened to find a good deal or if I was gonna change out the bars and needed more length or something.
GDI
GDI is offline
post #3 of 15 (permalink) Old 09-17-2018, 01:47 PM
Are you using motorcycle specific oil?
GDI likes this.
post #4 of 15 (permalink) Old 09-17-2018, 02:50 PM Thread Starter
yes I am. I'm using valvoline 10w-40, 4 stroke, wet clutch motorcycle oil
post #5 of 15 (permalink) Old 09-17-2018, 02:53 PM Thread Starter
GDI
When it happens it normally happens in all 5 gears. But is only really noticeable in the higher rpm range or when you try to accelerate. (like merging onto a 65 mph highway)
post #6 of 15 (permalink) Old 09-17-2018, 02:55 PM
Check your adjustment and cable. If you have no more room for adjustment you can pull the arm that the cable fits into and move it one spline on the shaft and get a few more miles our of it
post #7 of 15 (permalink) Old 09-17-2018, 03:00 PM Thread Starter
my brother recently helped me adjust it out and from what I remember its already at its farthest point so no more regular adjustment for it right now. would it be better to replace the cable at this point?
post #8 of 15 (permalink) Old 09-17-2018, 03:01 PM
GDI wrote - "Can't say for sure, but what you're describing would be consistent with a frayed clutch cable that is just about to give out."
This was my thought too. The lever play shouldn't change unless something is binding up somewhere. Had the same issue myself....and 20 miles later the cable broke. Lotsa fun riding 40 miles home, in the rain, through traffic, without a clutch
post #9 of 15 (permalink) Old 09-17-2018, 03:08 PM Thread Starter
so it shouldn't be the clutch itself right? this should just be a cable issue?
post #10 of 15 (permalink) Old 09-17-2018, 03:43 PM
Well hopefully. I'd check there first. There could be something binding somewhere farther down but you have to eliminate the cable before you go further.
The clutch cable ends at another lever on the motor. There's a spring there, and of course there are the springs in the clutch plates. Far more likely the cable is faulty before those others fail....
