Transmission whine? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 4 (permalink) Old 08-17-2018, 04:32 PM Thread Starter
Transmission whine?
Hey guys, so after dropping a valve a few weeks ago resulting in a see through piston, i managed to source an engine from a breakers yard. Had it shipped down from Scotland, visually in a sad state.
After a good clean and some paint, it's fitted & running well. However, there was a very slight, whine when riding, nothing when stationary. I thought it was wind noise at first. The chrome cap on the bevel housing then somehow fell off on the road and was throwing out oil.. I took the whine as a sign of wear, so I swapped out the bevel box with its internals for my old one cos i know it's good...
The whine is STILL there!! Although it's barely noticeable should i be worried? Any thoughts? I plan on lubing the shaft splines as they could do with grease, not sure if that could be it though.
jamiebont is offline
post #2 of 4 (permalink) Old 08-17-2018, 06:04 PM
I think they all some light whining to them. Mine does it, more of a whirring sort of noise from the engine, and the rear gear also has some harmonics in it at highway speeds.
Listen to some videos of rides on the 750.
post #3 of 4 (permalink) Old 08-17-2018, 06:11 PM
Likely could be a completely unrelated thing on the bike (like a vibrating cable) or it's something in the drive train.
Lube the spines (moly grease) and the front bevel gear (lithium grease) and see if that helps ....
post #4 of 4 (permalink) Old 08-17-2018, 06:17 PM Thread Starter
That's reassuring, thanks guys! Just found it strange that it's only started with the new engine, the bevel, shaft, final drive etc are the old ones and were silent before.
