Clutch release shaft oil leak. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
 2Likes
  • 1 Post By GDI
  • 1 Post By michiganteddybear
post #1 of 4 (permalink) Old 05-08-2018, 07:47 AM Thread Starter
dunthyon's Avatar
I don't know how but somehow while adjusting the clutch I managed to create a leak in the shaft oil seal. It's coming from the part that makes direct contact with the shaft and it refuses to quit leaking. Any ideas? Just bought a new seal just in case.
I have a love/hate relationship with this bike I swear to God.
dunthyon is offline
post #2 of 4 (permalink) Old 05-08-2018, 08:41 PM
GDI
I had a leak in that area. Mine turned out to be the outer stator cover. Any chance that you're seeing oil that blows back collecting on the clutch release? Fix was easy enough--just cleaned it up and daubed some RTV on it and put it back together. . . .
GDI
Spockster likes this.
GDI is offline
post #3 of 4 (permalink) Old 05-08-2018, 09:00 PM
also, shift shaft seal will leak and blow back that way as well
michiganteddybear is offline
post #4 of 4 (permalink) Old 05-09-2018, 12:19 AM Thread Starter
dunthyon's Avatar
I haven't moved the bike, and the oil is definitely coming from the clutch release seal because I wipe it off and i can see it come out from around the shaft itself. Definitely not blow back as I haven't ridden the Vulcan since I messed with the clutch.
dunthyon is offline
