Pilot jets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #1 of 18 (permalink) Old 01-07-2018, 07:00 PM Thread Starter
Pilot jets
Can anyone confirm if these jets will work. Some one on here posted the part numbers for these jets. But the pilot jet is a bit shorter. Any help would be appreciated.
Sent from my SM-G955U using Tapatalk
slipknotbrevin is offline
post #2 of 18 (permalink) Old 01-08-2018, 09:33 AM
ubertalldude's Avatar
Unfortunately it does not look like they will. Where did you order your jets from?
ubertalldude is offline
post #3 of 18 (permalink) Old 01-08-2018, 11:31 AM
JETHRO's Avatar
you have got the 25 series , should be 22 series, be ok then.
Vn 750 A2 1986 rebuilt engine, crank shaft, half casing,shell bearings,con rods,rear cylinder head,oil pump,water pump ,(had ceased bearing rusted up),tie bar upgrade,clutch basket drilled,front cylinder cam chains,toc springs,stator,shaved, rectifier,agm battery,solenoid ,starter motor (used) re-spray ongoing.
JETHRO is offline
post #4 of 18 (permalink) Old 01-08-2018, 11:33 AM
JETHRO's Avatar
the full number you need is N424-22 #40
JETHRO is offline
post #5 of 18 (permalink) Old 01-08-2018, 11:45 AM Thread Starter
Ok so I do need to order another set. In your experience would 42's be to big. 140's on the main. I have a set of those left from vn88. Pods/cruzers/cali emission delete.
post #6 of 18 (permalink) Old 01-08-2018, 12:58 PM
I have 42 pilot/142 main on pods with stock exhaust. I think it might be a bit too rich, but until I do some cruising at high altitudes (Florida is almost completely at sea level) I see no need to change it. I reckon 42 pilots would likely work for you based on your setup, and Plano doesn't have a high elevation, either.
post #7 of 18 (permalink) Old 01-08-2018, 02:52 PM Thread Starter
I'll give it a shot. Thanks for your help
post #8 of 18 (permalink) Old 01-12-2018, 03:19 PM
JETHRO's Avatar
I settled for 40/138 for my bike as 42 was too rich but as other members have said "it varies from bike to bike".
JETHRO is offline
post #9 of 18 (permalink) Old 01-12-2018, 11:50 PM Thread Starter
Mine came with factory 132/38. I did get the correct 40's ordered. With all I'm doing to it right now I'm gonna start at 140's. Fingers crossed but I don't think I should have an issue.
post #10 of 18 (permalink) Old 01-13-2018, 02:39 PM
I did 140/40 with earshave, degoated with screaming eagle mufflers at 1100 ft. elevation
thtanner likes this.
