No vents on gas tank? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 10-19-2017, 11:35 PM Thread Starter
Hello!
I found a gas tank that does not have vents. Is this common?
Thank you
Bill
willyb99 is offline
post #2 of 19 (permalink) Old 10-20-2017, 01:00 AM
the vents should be under the fuel cap
post #3 of 19 (permalink) Old 10-20-2017, 01:55 AM Thread Starter
OK, this tank doesn't have a cap. I am going to use the cap from the original tank. I guess what I really meant was the 2 emissions lines?
Also, does the black plastic cover over the fuel sender just pop off and there are screws holding the sender in?
willyb99 is offline
post #4 of 19 (permalink) Old 10-20-2017, 03:52 AM
I'm a rider
One1's Avatar
Tanks changed in the early 90’s. Before then there was no vent on the rear of the tank, just the cap...... unless it was a California model then it had two vents. Otherwise no vents until early 90’s where it had one vent from then on..... again unless it was a California model in which it still and always have had two.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #5 of 19 (permalink) Old 10-20-2017, 04:17 AM
Originally Posted by One1 View Post
Tanks changed in the early 90ís. Before then there was no vent on the rear of the tank, just the cap...... unless it was a California model then it had two vents. Otherwise no vents until early 90ís where it had one vent from then on..... again unless it was a California model in which it still and always have had two.
From what I can see the cap vents back down into an internal channel of the tank, presumably to the rear vent where the hose attaches. Did the pre-90's cap just vent to air at the top of the tank (and possibly vent fuel onto the rider)?
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #6 of 19 (permalink) Old 10-20-2017, 04:21 AM
I'm a rider
One1's Avatar
I read a good page somewhere about the tank changes a couple yrs ago and I’ve been trying to find it for 30 mins now. Doesn’t look like I’ll dig it up anytime soon.
Edit: in fact even though i read that and saw pictures, don’t mark it down until i find that source again.
1981 KZ750
One1 is offline
post #7 of 19 (permalink) Old 10-20-2017, 05:58 PM Thread Starter
Well it seems that this is not the original tank. I think it is in good shape. I took the cap off my first tank and I see where the cap had the vent (a little pin type object). This tank has no such provision. It looks like I am going to have to find out what year tank it is and buy a cap. Or I could stab a hole in the top of the tank....which should work, but recommended.
ID:	41450   Click image for larger version
willyb99 is offline
post #8 of 19 (permalink) Old 10-20-2017, 09:01 PM
cglennon's Avatar
Originally Posted by willyb99 View Post
Hello!
Thank you
Bill
Model years '85-'87 vent through a small port in the base of the gas cap. The port exit is located in the rear of the gas cap.
Model years '88 - '06 vent through a tube that run through the gas tank exiting at the rear of the tank.
Chris Glennon - Portland, OR
cglennon is offline
post #9 of 19 (permalink) Old 10-21-2017, 12:26 AM Thread Starter
So the 2 "pipes" I have on my '86 tank are emissions only? The tank I have now does not have any type of pipe, nor a cap. So it is possible it is an early 90's tank? Is there any way I an use it?
willyb99 is offline
post #10 of 19 (permalink) Old 10-21-2017, 05:43 AM
Saw on one post that the 85s had vent pipes. Hard to know what tanks got switched around, though, so it's hard to take anecdotal evidence as final. Seems more likely that 85-87 were all the same.
You can use the old tanks on new bikes, but you have to match the gas cap to the appropriate tank. You'd just rip out the now unused evap stuff from your frame and done (or you could leave it in-place and unused if you're feeling lazy). The late model vent hose to open-air has its equivalent in the gas-cap of the early models. Old way has more of a chance to purge pressurized gasoline/vapors onto the rider instead of being spat out onto the pavement via a hose.
Thorn is offline
