Removing Mixture Caps - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-15-2009, 12:15 PM Thread Starter
I just got the metal seals off the mixture screws and thought I would share the tecnique. I first used an awl to impress a small dimple on the little covers. Since you can't reach them at right angles the drills tend to skate off and could damage the carb body. After dimpling them I used a 1/16 drill bit in a pin vise and after about 5 minutes of hand turning I had a small hole. I then moved to a 1/8 bit and enlarged the hole. I put the tip of the awl in the hole and rocked it back and forth slowly until the cap popped of exposing the mixture screws. Now if I can pull the breather hoses off I'll finish marbling, adjust the mixture and if it warms up a bit, mount the V&H Cruzers. I hate Winter.
johngrindlinger is offline
post #2 of 5 (permalink) Old 02-17-2009, 08:33 PM
Wow, you worked WAY too hard!
I simply used a drill with a 1/16" bit and carefully drilled through the plug. Then I screwed a small wood screw into the plug and pulled it out with some pliers.
Whole ordeal lasted about 5 minutes and I had both carbs done and tools cleaned up...
BlwnGazkit is offline
post #3 of 5 (permalink) Old 02-23-2009, 11:40 PM
From his description, it sounds like he did it with the carbs on, hence the extra work
G_Loc is offline
post #4 of 5 (permalink) Old 02-24-2009, 08:31 AM
Ah... Yes I didn't catch that. It is more difficult with them on the bike.
post #5 of 5 (permalink) Old 02-25-2009, 01:36 PM Thread Starter
Yes they were on the bike. Because of the angle they are at and the soft metal of the carb bodies I was hesitant to use a drill or dremmel. I also had no idea of the distance between the caps and the mixture screws and was afraid I would drill right into them. As a side note, I changed the pipes this weekend to V&H Cruzers and had to adjust the mixture a little more. I was nervous after turning the mixture screws out about 3+ turns so I pushed the caps back on to keep the screw from comming out if I went too far. They pressed right in and with the hole in them they come right out with a bent paperclip.
