Need to rejet? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 02-03-2009, 12:58 AM Thread Starter
basherbob's Avatar
Need to rejet?
Last fall I purchased an1995 750 with about 23000 miles. The owner had recently installed Vance/Hines pipe and it sounds freakin awesome. The only concern is the incessant popping whenever you let off the throttle.
He did not rejet and the local service dept says it needs larger jets to make up for the pipes, nor did he have the carbs adjusted. Just add pipes and go! The Plugs had a white coating, not gray or brownish. I have noticed a lag of power at the top end even though has great low end torque.
What say all of you? Haven even cracked the carbs open so don't know what the stock jets are to order larger sizes.
Bob......
1995 VN 750
KN Air filters
Vance/Hines Pipes.
basherbob is offline
post #2 of 21 (permalink) Old 02-03-2009, 01:13 AM
The Professor
lance328's Avatar
Bob......
1995 VN 750
KN Air filters
Vance/Hines Pipes.
V&H with or without baffles? Stock air filter housings? Where do you live? Stock jets are #132 you should be fine with #135 The popping on deccel is due to the reed valves, you need to coaster or marble.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 21 (permalink) Old 02-03-2009, 06:37 AM
CWO3 Navy (Retired)
cliffhusn's Avatar
See my post on Marbling Coastering no more popping under carbs, I got rid of all my popping, the exhaust sounds great now.
https://www.vn750.com/forum/showthread.php?t=9499
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #4 of 21 (permalink) Old 02-03-2009, 08:31 AM
93VN750's Avatar
If the bike runs right, no hesitation or bogging and your plugs look like the correct color, don't mess with it.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 21 (permalink) Old 02-03-2009, 11:34 AM
I always thought the occasional pop sounded cool myself and i am a quiet pipes rider, should see the deer scatter when she pops
Mastertech is offline
post #6 of 21 (permalink) Old 02-03-2009, 12:09 PM
"ya can't live forever"
artman's Avatar
re jet
Yes re-jet.....go to Factory Pro they have a complete kit ready to go. By the way is the bike de-goated and the air box removed? If not you'll want to pull them out also then just hold on you'll be flyin'.
artman is offline
post #7 of 21 (permalink) Old 02-03-2009, 01:36 PM
The Professor
lance328's Avatar
The Factory Pro jet kit will have jet's that are too large unless you do an earshave. Just buy seperate jets that will work for about $12.00- $15.00 instead if a kit for $70.00 -$100.00.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 21 (permalink) Old 02-04-2009, 01:16 AM Thread Starter
basherbob's Avatar
OK I get the Marble... pretty ingenious... Kinda like what I did with the turbo bell hose on my Buick Grand National..
BUT WTF is deg-goating?
post #9 of 21 (permalink) Old 02-04-2009, 07:04 AM
The Professor
lance328's Avatar
With the V&H exhaust your scoot has been de-goated. The Goat's Belly is a pre-muffler chamber.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 21 (permalink) Old 02-27-2009, 05:36 PM
fergy's Avatar
Lance, I seem to notice some higher rpm lack of performance since I added the V&H's. Baffles in, and no other mods to air system except for K&N replacement air filters. I live in central Texas, altitude between 600 and 1400'. Would the 135 be right for my bike? And where would you order them?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
