Tank Repair - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 02-02-2009, 04:22 PM Thread Starter
flitecontrol's Avatar
Tank Repair
Dropped the bike and put too much pressure on the tank when I picked it up. Popped a spot weld loose on the left side tank attachment and caused a leak. Took it to several professional welders, and none of them would guarantee they wouldn't burn the paint and gold pinstriping on top of the tank. One wanted to stick weld, another to braze it. A friend offered to wire weld it. He notched the tab, heated it to bend it out of the way, and laid what looked like a good bead all the way around the triangular piece where the spot weld popped loose. By keeping wet rags around the weld area, he preserved the paint. Bent the tab back and welded it up. Unfortunately, there must be a pin hole in his weld as it still leaks! Anyone have any suggestions on how to fix this tank? I can't find any used tanks that match mine and don't want to spend over $400 to get a new one.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #2 of 21 (permalink) Old 02-02-2009, 05:39 PM
the doctor
billryx's Avatar
Doesn't Billy Mays have a super leak stopping epoxy! But wait isn't this another rip off. I know your pain original tank had many rust holes, bought a cheap bargin tank. it also had a leak. Just waited and found one on ebay that I liked, it doesn't leak and the OEM paint is quite nice, Mybe a nice low cost tank as a backup until you can find the weep hole and weld it shut for good.
bringing together
a dead
'86 VN750
"it's alive":"krechure"
billryx is offline
post #3 of 21 (permalink) Old 02-02-2009, 06:27 PM
The Professor
lance328's Avatar
You can use JB weld, just clean the area well.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 21 (permalink) Old 02-02-2009, 06:37 PM
Vintage bike addict
antiq's Avatar
Or PC7. There are epoxy kits at auto parts stores for sealing fuel tanks. Then there's a product called Seal All.
Eleanor Roosevelt.
antiq is offline
post #5 of 21 (permalink) Old 02-02-2009, 06:39 PM
On His Lady Vulcan
wkrizan's Avatar
I also had a leak in the same area and used so much JB weld that I should have bought stock in the company. The problem that I was experiencing with using JB in that area was when you went to tighten down the tank bolt it would continually break the weld. My recommendation is to watch ebay closely and find a deal on a good used one. Don't use that tank sealant crap thats out there either. Good luck.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #6 of 21 (permalink) Old 02-02-2009, 07:00 PM
Vintage bike addict
antiq's Avatar
Your welder friend could try silver solder with a micro torch. If it works it should hold.
Eleanor Roosevelt.
antiq is offline
post #7 of 21 (permalink) Old 02-02-2009, 09:48 PM Thread Starter
I started out using JB weld when it first leaked. Stopped the leak, but like wkrizan said, when I put it on, I heard a faint "pop" while tightening the bolts. Sure enough, it leaked again. Spent five hours and broke two dental tools getting the JB weld out! The tank was sealed at the stealership by the PO. Not sure what adding more would do, but that is a possibility too. Think I read a thread (by fergy?) about cleaning rust from a tank with nuts and muriatic acid. Anybody know if that will remove tank liner?
Hadn't thought about solder; I could do that! My mind associates solder with electrical connections.
I'm also looking at a spare tank on ebay. Nothing matches mine and I sure would like to keep her looking uniform; she's a beautiful thing. But I've had her over a month and only put two miles on her! I want to get her on the road ASAP, and if that means getting a spare tank, I'll do it!
Open to any other suggestions too!
"Black Beauty"
Old Blue
post #8 of 21 (permalink) Old 02-02-2009, 09:55 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I just put a thread in the carbs section on a new Fuel Tank still in the box I saw on Ebay this evening, bid is $300, buy it now for $400...might want to check it out...
http://cgi.ebay.com/ebaymotors/VULCA...Q5fAccessories
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #9 of 21 (permalink) Old 02-02-2009, 10:04 PM Thread Starter
Thanks Cliff, already have.
"Black Beauty"
Old Blue
post #10 of 21 (permalink) Old 02-02-2009, 10:30 PM
The Professor
lance328's Avatar
What color is your tank?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
