Oil in the air breather.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 7Likes
post #1 of 47 (permalink) Old 08-02-2017, 12:28 AM Thread Starter
OK so I just Bought my bike yesterday . it's a 86 Vulcan 750. When I got it home and jumped the battery the bike turned over really slow and back fired After reading some threads on this site I was relieved to find out it was most likely do to the battery being bad so I bought a new battery for her and walla she fired up, but after running for about ten minute's she quit and wouldn't start up again. I got her running again today and noticed she was smoking white smoke out both exhaust pipes. Smells like it's running rich, don't smell like oil or anti freeze. She didn't quit on me today but as she warned up to normal operating temp I noticed I'll coming out of the breather case I pulled the cover and it was flooded with oil. I did some reading on here and I see that it could be that it's over full on oil so I'll be checking that after work tomorrow, my question is, is could the smoke be from it sucking oil up thru the air breather, and mixing with the gas in the carbs.... Any help would be appreciated. Thanks
Jdjb021970 is offline
post #2 of 47 (permalink) Old 08-02-2017, 12:33 AM
yup over full oil will make it smoke.check your oil for a gas smell,as you may be flooding
post #3 of 47 (permalink) Old 08-02-2017, 04:45 AM
OldDirtyDoc makes a great point about checking for a gasoline leak as the cause of the high oil level. Definitely want to get the carb and/or petcock fixed. Hopefully the PO was just really bad at measuring.
Also, "Voila".
TheJabberWoggy likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #4 of 47 (permalink) Old 08-02-2017, 01:13 PM Thread Starter
Thanks guys I'll definitely check that tonight when I get home if the oil smells like gas would that be from flooding the carbs or is there something else more serious going on?
post #5 of 47 (permalink) Old 08-02-2017, 02:26 PM
Likely culprit would be a stuck carb float causing flooding.
One1 likes this.
Thorn is offline
post #6 of 47 (permalink) Old 08-02-2017, 03:54 PM
Or leaking through the petcock vacuum line.
One1 likes this.
post #7 of 47 (permalink) Old 08-02-2017, 06:53 PM
I'm a rider
One1's Avatar
Agree with everyone above. A leaking petcock seal, or float valve needle will fill the crankcase with gas and cause blowback through the crankcase vent into the airbox. To be that overfilled it's unlikely that he overfilled it very likely the crankcase is flooded with gas. You can't drive it that way obviously with no lubrication, but worse the stator will get hotter and its already an issue to begin with. Drain the oil before you crank it again and check it for gas. I just went through this with my kawasaki KLX and had to rebuild the carb and petcock.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #8 of 47 (permalink) Old 08-02-2017, 07:21 PM
When mine did it, the shifter started feeling sticky after it got good and warmed up.
post #9 of 47 (permalink) Old 08-04-2017, 11:37 PM Thread Starter
OK so I checked the oil it was over full I drained it down till it was half way up the check window. I thought my problem was solved, when I started it it didn't smoke I let it warm up and when I brought the idle to around to 2000 rpm, and it started smoking again and pouring oil out the left side air breather again. The oil does have a trace of gasoline smell to it but not like the oil is flooded with gas. What would make the oil come out of the air breather if the oil level is normal. I'm sure the smoking is because the oil is being pulled thru carbs and being burned. Like i said it didn't start smoking again until I brought the rpms up to around 2000 and that's when the oil started coming out the air breather again.. Thanks for all your help.
post #10 of 47 (permalink) Old 08-04-2017, 11:52 PM
I would pull the crankcase breather hose loose and see if there's a lot of positive pressure from the crankcase, at idle and revving.
Sounds like there might be a burned or broken piston/broken rings. If it's pushing oil out of the crankcase breather, it's terminal.
Does it seem to be running on one cylinder?
Otherwise, .. Raw gas getting into the pipes can cause white smoke, but it will smell like gas and not burned oil.
Gassy smelling oil has gas in it. It shouldn't be there.
