Fresh rebuild leaking like a sieve - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-29-2017, 03:41 PM Thread Starter
Hey all, been doing some reading on this issue, but haven't nailed down anything definitive. I just rebuilt my carbs, ear shaved, rejetted, etc. Everything rubber was replaced, o-rings, diaphragms, fuel lines. Got the bike running, and now my carbs are leaking like crazy. It looks like the leak is coming from the float bowls. When I rebuilt the carbs I did not replace the needle valves as the rubber still felt great, nice and sharp. One thing I'm seeing in some of the rebuild threads that I totally missed and neglected to do was to adjust the floats. Could this be what is causing the leak, or is there some other stupid mistake I could have made?
Nate Swanson is offline
post #2 of 3 (permalink) Old 07-29-2017, 08:49 PM
Other than not replacing the needle valves and seats?
Float height could be the culprit, either way looks like you'll need to yank the cabs again..
post #3 of 3 (permalink) Old 07-29-2017, 09:30 PM
Floats could be stuck, sometimes firmly rapping the carb bowl with a plastic screwdriver handle can free them.
Always shake the float when it's removed to be sure it hasn't filled with gas.
