Carb Cleaning Additive advice - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 01-20-2009, 09:11 AM Thread Starter
Question Carb Cleaning Additive advice
I am suspecting the low speed jet on one carb may be blocked - unable to raise little throttle on on a warm engine. It Idles ok and I can raise the throttle way up as well - but wont hold if i raise it to 1500 rpm.
I do see a lot of SEAFOAM articles - would that be the way to possibly clear the low speed jet or is there something else ?
Thanks
Not a Virgin but has a Halo
RogerGA is offline
post #2 of 16 (permalink) Old 01-20-2009, 09:16 AM
Scootergptx's Avatar
That would be the first step I'd take. Much easier to open the gas tank and pour some in than trying to get the carbs off. I'd fill the tank (with gas), put in about 5-6 ounces of SeaFoam and go for a nice ride.
Hopefully, it will loosen up whatever was causing the problem. If not, at least you got to take a nice ride before you had to work on it.
Global warming? So what if my kids never see a polar bear. I never saw a dinosaur and I'm ok.
Scootergptx is offline
post #3 of 16 (permalink) Old 01-20-2009, 01:55 PM
The Professor
lance328's Avatar
Thanks
Seaoam video that dirttrack650 had posted.
http://video.google.com/videoplay?do...26229173&hl=en
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 16 (permalink) Old 01-20-2009, 02:19 PM
Calif Rider
weh44att's Avatar
Did you do a good draining of the the fuel tank and the Carbs. I really think that a good draining of the carbs is needed more often if you ride alot. I plan to drain mine about every 6 months. Last time I drained them there was evidance of a few particles in the gas that was drained into a white rag.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 16 (permalink) Old 01-20-2009, 03:04 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I run Seafoam in every tankful. Haven't had a problem since doing this. Is the engine stumbling at all? Might want to check the air hose in the air filter housing to see if it's hitting the side of the housing and not letting air in. Happened to me and I secured it so it won't happen again, hasn't stumbled since. Just a thought.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #6 of 16 (permalink) Old 01-20-2009, 08:02 PM
You might want to check fuel line routing.: i had that problem and found a pinched (to tight a bend) fuel line! Good luck!!
BIRDDOG 54 is offline
post #7 of 16 (permalink) Old 01-20-2009, 08:54 PM Thread Starter
Thanks Ill check everything and also drain before i Start the Seafoam. Just picked it up from Pepboys
RogerGA is offline
post #8 of 16 (permalink) Old 01-21-2009, 11:05 AM
Vintage bike addict
antiq's Avatar
best of luck to you. While you ride chop the throttle once in a while to get max vacuum to the carbs and draw fuel threough the low speed jets. This may just fix the problem. I've done it with good result a few times on my bikes.
Eleanor Roosevelt.
antiq is offline
post #9 of 16 (permalink) Old 01-21-2009, 05:34 PM Thread Starter
Chop the throttle - you mean a sudden throttle open and close ?
Ok i checked all the lines - seemed fine
I placed a tissue below the drain and drained the carb end - Tissue did not show any loose grains or deposits - assuming there is no loose dust or rust
Just poured some seafoam in - its too cold to ride!! Took a small ride inside the streets and came back - will wait for the weather god to be more considerate
Thanks again all
R
RogerGA is offline
post #10 of 16 (permalink) Old 01-21-2009, 05:58 PM
Vintage bike addict
antiq's Avatar
I mean run at higher RPM and suddenly close the throttle. Let the motorcycle coast down in gear a few seconds at a time. Then repeat. Don't allow this activity to endanger your ride. No one should be following when you do this.The idea is to force fuel through the idle jets with the extra vacuum caused when the motor is forced to run with a closed throttle by sheer momentum of the bike. That was my theory when I tried it on my Virago and it did work. I'm still not certain if my theory was correct or why it worked but I was sure happy to avoid removing the carbs.
Eleanor Roosevelt.
antiq is offline
Tags
carb cleaner
