Gas Tank Line Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By michiganteddybear
post #1 of 4 (permalink) Old 07-19-2017, 04:50 PM Thread Starter
Location: Sometimes Westchester, sometimes Plattsburgh, NY
Gas Tank Line Help
So recently, I've crashed my 750, and I am having trouble finding where line marked '702' on the gas tank diagram connects to, I cannot find any loose lines, so I am wondering where exactly would this connect to,
SergheiS is offline
post #2 of 4 (permalink) Old 07-19-2017, 06:03 PM
on a non california emissions model, the only fitting on the bottom/rear of the tank connects to a hose that goes down to vent out below the bikes frame (its the fuel tank vent).
california emissions have 2 fittings, one for the same vent as above, and one for the charcoal cannister that they had
michiganteddybear is offline
post #3 of 4 (permalink) Old 07-19-2017, 06:11 PM Thread Starter
I'm not sure if this bike is California or not, just know that after I crashed and tried to pick up the bike, I had to let it lay on its right side, and it would slowly drip gasoline out that tube, so I'm not sure if it needs to be reconnected to something, or does it just sit on its own.
On that note, where would the fuel line be on the gas tank? Because on that diagram that 702 tube seems like the only outlet. If this is the only opening I see, and some gas cap leakage, is it safe to attempt to start just to see if it still runs?
SergheiS is offline
post #4 of 4 (permalink) Old 07-19-2017, 11:12 PM
the fuel outlet (petcock is on left side of tank, bottom). stock unit has 3 hoses, 2 for feeding fuel to carbs, one from left side carb's vacuum port to enable the valve in petcock to open and allow fuel flow.
if the tank was fairly full, its entirely possible to get fuel out of the vent line if the bikes on the side. that vent hose is only connected on one end (to nipple on fuel tank, near the seat). other end is open
SergheiS likes this.
