Electrolytic tank rust technique problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By OleDirtyDoc
  • 1 Post By Goofyfoot2001
post #1 of 7 (permalink) Old 07-08-2017, 10:37 PM Thread Starter
Unhappy Electrolytic tank rust technique problems
I am following the directions out of the Vulcan Verses on tank rust treatment using a battery charger.
However, my battery charge keeps tripping some sort of safety feature after just a second or two. I have he black lead from the charger hooked to the tap at the end of the teardrop tank shape. sparks when hooked up which indicates good connections. Red lead hooked to both black and white 14 gauge wires which have other ends wrapped around zinc bolt in SP up / water solution in tank.
Charger starts up and then makes audible circuit cut off click. After a while will try again.
What am I doing wrong, please????
BillinAustin is offline
post #2 of 7 (permalink) Old 07-08-2017, 10:50 PM
Need to be sure the bolt is hanging suspended in the liquid, but not touching the tank. If it touches the tank, it's a dead short.
post #3 of 7 (permalink) Old 07-09-2017, 04:04 AM
yup.that's why your battery charger is shutting off
post #4 of 7 (permalink) Old 07-10-2017, 01:15 AM Thread Starter
Thanks. It has started working, I'll let you know the end result.
post #5 of 7 (permalink) Old 07-10-2017, 08:49 AM
ok I have never heard of this in all the years I've been on here. I must learn this magic.
post #6 of 7 (permalink) Old 07-10-2017, 10:31 AM
https://www.vn750.com/forum/42-body/1153-rust-tank.html
here is the spell you are looking for
Thorn likes this.
post #7 of 7 (permalink) Old 07-10-2017, 05:12 PM
Well that is just cool as ****
Thorn likes this.
