Rerouting of cooling lines for using K&N filter RC-3240 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 2 Post By Jumpingjerry
post #1 of 8 (permalink) Old 06-25-2017, 06:16 PM Thread Starter
Jumpingjerry's Avatar
Decided to do the K&N filter that AceMcqyer posted about in 2009. I went this route because I liked the fact that the filter was under the tank and out of the rain. I commute ran or shine. So anyway I went with the shorter K&N so I wouldn't have to modify the cooling lines. It worked fine, but was tight in there and a little crooked. Also the cooling line spring would rub on the filter and it started to wear the on the filter a little. So it looks like AceMcqyer had it right the first time. I was a little nervous about doing this, but I knew I could do it. Not as neat as AceMcqyyers, but I think it will work. I will attached a U shaped hose on the left side, along with a "L" fitting to get the hose lower and out of the way of the filter. I'll post more pictures when I get there. So far the pipe coming off the thermostat housing is completed.
I used a 1 1/16" drill bit to make the hole. Cut off the bottom end and attached it to the hole I cut. Not the best at brazing, but it should hold up. Capped the top off with the end of a carriage bolt (it is what I found laying around the garage).
ID:	38425   Click image for larger version
ID:	38433   Click image for larger version
ID:	38441   Click image for larger version
ID:	38449   Click image for larger version
Jumpingjerry is offline
post #2 of 8 (permalink) Old 06-25-2017, 06:17 PM Thread Starter
Here it is all painted up. I had flat black paint left over so it's what I used. It's not fancy but should work.
OleDirtyDoc and thtanner like this.
post #3 of 8 (permalink) Old 06-25-2017, 09:18 PM Thread Starter
Installed! Just waiting on parts now.
post #4 of 8 (permalink) Old 06-25-2017, 09:20 PM
sweet. I love threads like this
post #5 of 8 (permalink) Old 06-25-2017, 11:15 PM Thread Starter
Thanks!
Shortened the rear cooling tube so the rear of the hose would be lower too.
ID:	38481   Click image for larger version
post #6 of 8 (permalink) Old 06-26-2017, 02:18 PM
https://www.vn750.com/forum/22-carbs-...ear-shave.html original thread
post #7 of 8 (permalink) Old 06-26-2017, 07:22 PM Thread Starter
Thanks! I meant to post that.
post #8 of 8 (permalink) Old 06-26-2017, 09:14 PM Thread Starter
Got the rest of the coolant lines in. Should have plenty of room now for the air filter.
