Replaced leaky petcock, now it doesn't run right. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 14 (permalink) Old 06-15-2017, 09:52 PM Thread Starter
Jumpingjerry's Avatar
I have a 2003 Vulcan with about 2800 miles on it. Been siting for years. Got it running good. Ear shave and coasters done. Ran with no problem for the past week, except the petcock had a small leak. Installed new petcock today. Now it seems to have an oscillating hesitation. Runs good, then boggs for a second, then runs good, and boggs, then runs good, and boggs......
No more leaking though. The petcock is new OEM.
2003 Vulcan 750
Jumpingjerry is offline
post #2 of 14 (permalink) Old 06-16-2017, 10:07 AM Thread Starter
I'm thinking the new petcock diaphragm could be stuck? Who knows how long it's been sitting on a shelf somewhere.
post #3 of 14 (permalink) Old 06-16-2017, 10:30 AM
Yes sounds like it's not flowing fuel properly. You can check this by running two fuel lines from the petcock into a jar, and then applying some suction to the vacuum line.
You can use your mouth or one of these:
https://www.walmart.com/ip/Bulb-Syri...rator/39791322
If the flow seems to swell and then die, you've found your culprit....
post #4 of 14 (permalink) Old 06-16-2017, 10:37 AM
another less likely cause would be inadequate tank venting. may need to clean the vent in the cap and the vent lines
michiganteddybear is offline
post #5 of 14 (permalink) Old 06-16-2017, 01:47 PM
"Got it running WELL."
"Runs WELL, then boggs for a second, then runs WELL, and boggs, then runs WELLER, and boggs......
post #6 of 14 (permalink) Old 06-16-2017, 01:48 PM
Slow day
Jumpingjerry likes this.
post #7 of 14 (permalink) Old 06-16-2017, 10:47 PM Thread Starter
Thanks! I'll give that a try.
I did clean it last week, but I'll check it again.
post #8 of 14 (permalink) Old 06-17-2017, 03:31 PM
NewB to Vulcans
TonyO's Avatar
Did you replace the fuel hoses? I cut mine a touch too long and after a while it kinked enough to cut off one cylinder.
'99 Vulcan "Victoria"
TonyO is offline
post #9 of 14 (permalink) Old 06-18-2017, 10:53 AM Thread Starter
They are new hoses. I've checked to make sure they are linked.
post #10 of 14 (permalink) Old 06-18-2017, 11:11 AM Thread Starter
So out of curiosity I took the old petcock apart. Found out that there was no spring in it. So the old one was working like a gravity petcock and worked great (except for the minor leak). Figured I would make the new one gravity fed petcock too. That seemed to fix my problem. The bike is running good now! I took out the plunger in the new petcock and soldered the vacuum nipple shut. I did use a manometer on the carbs and they both seems to have same vacuum on them.
ID:	38050   Click image for larger version
ID:	38074   Click image for larger version
