New to the Vulcan. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-07-2017, 10:40 AM Thread Starter
Jumpingjerry's Avatar
New to the Vulcan.
Hello all! First off what a great site! I've been doing a lot of reading! Great information!
I picked up a 2003 Vulcan with 2673 miles on it. It's been sitting for years. Got the carbs cleaned and unning at idle and slow speed. Got to ride it for the first time yesterday. It did great untill I got up to highway speeds. It bogged down. Still a work in progress. I'll keep reading and I'll get it figured out!
I did find a mud dauber in the fuel line! The jets were filthy! It's getting there. Coasters on the way and K&N RC-3240 should be here today.
ID:	37794   Click image for larger version
Jumpingjerry is offline
post #2 of 12 (permalink) Old 06-07-2017, 11:01 AM
ubertalldude's Avatar
Nice work! Good god those carbs were dirty...
As for the high speed bog, you may be running into an issue with the carb vent hose, which needs to be open but tucked away somewhere the wind doesn't hit it. If you have the stock earboxes there's a small spot for it in the right airbox, if you removed the stock airbox then tuck it above the top frame rail so it's shielded from the wind by the tank. That might help with high speed bogging
ubertalldude is offline
post #3 of 12 (permalink) Old 06-07-2017, 11:46 AM Thread Starter
Thanks for the tip. I put a filter on the carb vents and it is in the frame rails up front. It should be shielded from the wind, but I'll double check it tonight when I get home.
I do know I will need to synchronize the carbs. Still lots to learn and do.
post #4 of 12 (permalink) Old 06-07-2017, 01:53 PM
I had a filter on mine but it was causing issues. The tube doesn't draw much air so it shouldn't ever get much dirt in it. That may be worth taking off of there, 'cause it certainly helped on mine, and it's not gonna get all that dirty anyhow
post #5 of 12 (permalink) Old 06-07-2017, 02:34 PM
fasten it to the spare nipple (who doesn't love spare nipples hehe)on the bottom of the fuel guage sender under the gas tank
post #6 of 12 (permalink) Old 06-07-2017, 03:07 PM Thread Starter
Thanks y'all!
post #7 of 12 (permalink) Old 06-07-2017, 03:10 PM
Put a piece of tape on the leading edge of the filter.
post #8 of 12 (permalink) Old 06-07-2017, 10:38 PM Thread Starter
Did an ear shave mod and installed the K&N RC-3240. Also clean the gas cap. That seems to work!
Plugged the emissions off untill the coasters come in tomorrow.
Left the filter on for the carb vents.
It ran great on my test drive. Got up to 80-90 no problem. I'm so stoked!!!
ID:	37826   Click image for larger version
ID:	37834   Click image for larger version
ID:	37842   Click image for larger version
ID:	37850   Click image for larger version
post #9 of 12 (permalink) Old 06-08-2017, 12:27 AM
sweet. looks pretty cool
post #10 of 12 (permalink) Old 06-09-2017, 10:42 PM Thread Starter
Thanks!
