I admitted defeat and brought her to a shop...Now what? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 7Likes
post #1 of 68 (permalink) Old 06-03-2017, 07:53 PM Thread Starter
After a month of fiddling with her, I finally broke down and brought my baby to a shop. The problem that has been plaguing me was that she got super sluggish and bogged down (almost like one cylinder firing inconsistently), then eventually die altogether on lower RPM's. After a while, she would eventually run great all the way through the powerband, only to then sputter out and die 10 minutes later. Waiting a few days would then make her fun again for only 10 minutes, rinse and repeat.
So I brought her to a shop near me. They took apart and cleaned the carbs, fixed some messy work of mine from the rebuild, and said she's good to go! Well if you see me posting on this forum you know things aren't running right.
Now what's happening is above ~30 mph the bike does the exact same thing as before, although now the problem is happening all the time. Very sluggish and bogging down. I immediately brought it back to the shop after picking it up. The theory that the mechanic at the shop gave me was that one of my pod filters was in direct view of the forwards wind, therefor forcing air into that carb. I was unsure, only because I've had 900 miles since the rebuild with pod filters without ANY issues. So I come to you handsome folks once again to beg for help
Any ideas?
(I'd like to note that over those 900 miles the bike would become sluggish just like this problem, although it only happened 2-3 times ever. After riding for a while she would begin to bog down. After waiting a minute or two on the side of the road she would start right back up without issues. Almost like the phantom out of gas issue. Now it's become a regular occurrence. I have a new tank that's properly vented btw.)
'86 VN750
snoopyonderdonk is offline
post #2 of 68 (permalink) Old 06-03-2017, 07:56 PM
carb vent hose.. either not in clean, non-turbulent air, or its kinked.
since you shaved, common location is under tank, either secured to top of frame rail, or connected to the nipple on the cover for the fuel sender unit
michiganteddybear is offline
post #3 of 68 (permalink) Old 06-03-2017, 08:04 PM Thread Starter
One of the things they fixed was the carb vent hose. They relocated it to under the tank, cut at a 45 degree angle. Before I had it sticking out on the right side of the bike directly in the wind
'86 VN750
post #4 of 68 (permalink) Old 06-04-2017, 09:29 AM
relocated to under tank is not enough, it needs to be above the frame rails, or on top side at minimum (where mine is), and for what its worth (shouldnt be an issue for you tho), mine is cut square. next thing would be to check that the vent lines from both carbs are going into a T fitting, then up under tank. or make sure they didnt hook the wrong hoses to the vents (I have heard of shops that put the fuel feed from petcock onto the vent ports)
post #5 of 68 (permalink) Old 06-04-2017, 10:09 AM
fully agree. Michigan helped me with the same issue you have. After the shop fixed the carb - the lines were hooked up incorrect. his knowledge helped greatly.
Brooklyn_Vulcan is offline
post #6 of 68 (permalink) Old 06-04-2017, 10:56 AM Thread Starter
You think the height of the carb vent tube would fix that? I'll check it out though As well as whether they hooked everything up correctly too
'86 VN750
post #7 of 68 (permalink) Old 06-04-2017, 11:11 AM
I agree with teddybear. try putting the hose on the nipple (I LOVE saying that word )on the sender.that's a common problem people have with the earshave
post #8 of 68 (permalink) Old 06-04-2017, 11:50 AM Thread Starter
Wait, sorry. The carb vent hose on what now? The petcock vacuum?
'86 VN750
post #9 of 68 (permalink) Old 06-04-2017, 12:13 PM
there's a nipple on the bottom of the fuel gauge sender that most hook the carb vent line to
post #10 of 68 (permalink) Old 06-04-2017, 02:36 PM
No..
They said the fuel gauge sender, not the petcock.
It's in the middle, directly under the tank (ON the tank itself.) It's a square plastic piece with a nipple on it. Use that nipple for the carb vent hose.
