Air/Fuel manifesto - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 12-19-2008, 10:23 AM Thread Starter
fiendclub36's Avatar
Air/Fuel manifesto
i adjusted my carbs to about 3-1/2 turns. the mixture is perfect now but i was told by someone that it was too much. so far i have had no problems, but wondering why it would be too much? is it because the screw/ spring will fall out? thanks - tim
fiendclub36 is offline
post #2 of 9 (permalink) Old 12-19-2008, 10:26 AM
750Doug's Avatar
I've seen posted here before that it can fall out around 3.5-4 turns. You could get in there with a flashlight, (bike off) and find out for sure, but I think you're close to the edge.
750Doug is offline
post #3 of 9 (permalink) Old 12-19-2008, 12:06 PM
There's a spring behind that screw? I never Knew. Where would it go if it fell out?
There it is! The spring #92081
post #4 of 9 (permalink) Old 12-19-2008, 04:20 PM
Just to clarify (and sorry for the thread jack), but you guys screw them in all the way and then count the turns as backing out from that point on, correct?
G_Loc is offline
post #5 of 9 (permalink) Old 12-19-2008, 05:09 PM
It will fall out on to the road. btw, the screw needle will fall out too. (16014)
post #6 of 9 (permalink) Old 12-19-2008, 06:27 PM
yes you are correct
post #7 of 9 (permalink) Old 12-20-2008, 08:00 AM
If that is perfect and you still have threads catching a little (and I mean a very little) drop of locktite and an overnite dry should hold the screw in. Or another method would be a dab of clear RTV on top of the screw, it might be easier to pick out than getting the locktite loose.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 9 (permalink) Old 12-20-2008, 09:26 AM
I won't say exactly how far mine is adjusted because I wouldn't recomend it to anyone. But I do know you have more than 3 1/2 turns of that screw & it won't fall out. Atleast Mine is snug. Mine's also so wack adjusted because I'm shaved without rejetting & colortune adjusted (I can see the fire). It's quite extreme I know but, you should be very safe at 3 turns & the RTV to plug it is an exellent idea. I'm going to steel that one!
post #9 of 9 (permalink) Old 12-22-2008, 08:07 AM
"ya can't live forever"
artman's Avatar
Factory Pro says that 5 turns is the max.
artman is offline
