Did the ear shave and coastering... but - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 12-08-2008, 12:18 AM Thread Starter
Finally did the ear shave and coasters! Sure does look much better and seems a bit louder.
The bike wouldn't start at first until I pulled one of the air filters and covered up the intake with my hand. Started up, I put the filter on, adjusted the idle, and it seemed to be running just fine!
I had dumped the remainder of my SeaForm bottle in the 3/4 full tank, so it was a bit smoky. However, I noticed smoke coming from the rear cylinder's exhaust where it meets the head. I have never seen smoke coming out of there. I guess since the SeaFoam makes the exhaust smoke so much that the once invisible exhaust leak is now... visible. I saw this before doing the conversion while using SeaFoam, so I don't think its something I did.
Plausible?
G_Loc is offline
post #2 of 24 (permalink) Old 12-08-2008, 01:12 AM
id recomend new crush gaskets.... alot of the guys on here can give you the actuall part number or you could just search for them.... i think they are around like 10-20$... could be cheape..... not exatcly sure
bigrepp61 is offline
post #3 of 24 (permalink) Old 12-08-2008, 02:57 AM
Addicted to Projects
bullwinkle's Avatar
I think they are something that can be purchased at the Hardly Davison shop (they usually have them in stock, a dealer most times has to order them)
Charlie
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #4 of 24 (permalink) Old 12-08-2008, 09:18 AM
post #5 of 24 (permalink) Old 12-08-2008, 10:28 AM
I bought two sets at HD just in case I wanted to put my jardines back on. They were less than 20$.
post #6 of 24 (permalink) Old 12-14-2008, 12:56 AM Thread Starter
Well I finished putting it together today and wow, it hasn't run this well in a while!! Didn't notice any smoke though. I think I will order a set of gaskets to keep around just in case I need them...
Thanks for the part number!!
G_Loc is offline
post #7 of 24 (permalink) Old 12-14-2008, 07:01 PM
Calif Rider
weh44att's Avatar
Make sure that the exhaust header nuts or fully tight. I found one of mine missing just the other day. I just installed a new nut and my exhaust leak went away, you may not really need new gaskets. My bike is a 04 not that old, if yours is a lot older maybe new gaskets would be the way to go.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #8 of 24 (permalink) Old 12-14-2008, 11:14 PM Thread Starter
Mine is also an 04.
I took it for a ~40 mile drive today and it burned through nearly 2/3 of my tank of gas!!! When trying to troubleshoot my stumbling issues, I poured nearly the entire SeaFoam can in there, could that have killed my mileage? Ran like a champ though... and started up right away, which it never did, not even when new!
G_Loc is offline
post #9 of 24 (permalink) Old 12-14-2008, 11:36 PM
Just a thought, did you open up the choke after warm up???
post #10 of 24 (permalink) Old 12-15-2008, 09:12 AM Thread Starter
Yup... One thing I did notice is that sometimes my RPMs would tend to hover near 2k for a few seconds after rolling off the throttle. Then it would go back down to 900rpm or so
G_Loc is offline
