Gas Cap Lock - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 11-20-2008, 09:24 PM Thread Starter
Gas Cap Lock
God I hate the cold. Tonight i wanted to drain my gas tank because it is getting cold and I can't ride to work any more. Upon inserting my key and trying to unlock my gas cap, the key broke off in the cap...then took out my spare key and it didn't budge the lock either...I had to pry the lock apart and use a screw driver to force the lock. Now I have to rekey my bike...although I am thinking of waiting until I come back on R&R to fix it.
post #2 of 23 (permalink) Old 11-20-2008, 09:43 PM
Love My Baby
rubyrick's Avatar
OH NO, say it isn't so...
That really sucks. It must be freezing cold up there, Slim. You've got to come down to sunny Florida for a warm escape.
I hope you didn't scratch the u-know-what out of your tank.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #3 of 23 (permalink) Old 11-20-2008, 10:47 PM
Check to see if the key has any numbers on it. Mind did, and the locksmith was able to make a new key from the numbers. He might be able to make a key from the 2 halfs if you are lucky.
tprender is offline
post #4 of 23 (permalink) Old 11-23-2008, 12:03 PM Thread Starter
I found my spare key...so having a key isn't an issue...I found the key too late though and destroyed the lock on the gas cap.
and no I did not scratch the tank...I might have scratched the fuel cap, but not the tank
post #5 of 23 (permalink) Old 11-23-2008, 08:42 PM
Sorry to hear about your lock trouble slim. Was the lock frozen or a mechanical problem? For anyone not used to dealing with freezing weather and auto or motorcycle locks, there are a few things you can do to avoid breaking keys off.
1. Preventative medicine-squirt in a little powered graphite lubricant now, before you need it and work the key in and out several times as well as back and forth, to smooth the lock up.
2. Little bottle of alcohol to squirt in frozen lock to free it up so you can turn it.
3. If your key head is all metal with no rubber or plastic permenantly attached, you can try heating it with a lighter ( a windproof one works best )and putting it in repeatedly until it thaws the ice in the lock enough to turn the key. If you`re at home a hair blow dryer might work too. Good luck.
post #6 of 23 (permalink) Old 11-23-2008, 09:07 PM
That`s a PITA slim. Is this the first winter with freezing weather for you? Check the service station for a small bottle of methyl alcohol to squirt in a frozen lock, to displace the ice. It works ok usually, if the temp is only a few degrees below freezing. If it is really cold, you need to heat the key with a lighter (wind proof is best) or a small torch or heat gun. Flames are ok for a door lock, but be careful around the gas tank.
When you get it open, squirt in some powdered graphite lubricant. It might help prevent it from happening again. Good luck.
P.S.- I didn`t mean to post this twice. I thought I lost the first post and rewrote this one.
post #7 of 23 (permalink) Old 11-23-2008, 09:57 PM Thread Starter
not my first winter...not even close...no it wasn't frozen..That was my first thought... but after breaking the lock I decided to tear apart the gas cap to see how hard it will be for me to rekey it...I found the locking mechanism rusted very badly. So a new gas cap is in order
post #8 of 23 (permalink) Old 11-24-2008, 12:47 AM
The Professor
lance328's Avatar
Just wanted to let you know if you buy a new one from Ma Kaw the lock cylinder is not included.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 23 (permalink) Old 11-24-2008, 01:10 AM
tincanman's Avatar
Wow. That's a bummer. I have to say that my key is weak from getting bent in the lock, and then straightened, too many times. I pulled the cap, disassembled the whole thing and lubed with graphite, but it's still just a stubborn piece on both my Vulcans. Any ideas? I've thought of changing the whole tank out and turning it into a gravity feed system, but...
The Hos '93 VN750
New fork seals, tires next
Thunderbolt '81 KZ1000 M1
Down from cam chain tensioner malfunction
My window is always down when I drive because I'd rather be on my motorcycle.
tincanman is offline
post #10 of 23 (permalink) Old 11-24-2008, 01:28 AM
The Professor
lance328's Avatar
I use a few drops of Marvel air tool oil in ALL lock cylinders including ignition. It has Rust, Corrosion, and Moisture inhibiters. Works Great!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
