Coastering procedure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 02-20-2017, 11:52 PM Thread Starter
C_Wage's Avatar
Hey there,
I am planning on putting on coasters and pulling all the fuel emission parts that go along with that. Planning on doing the ear shave later but thought I would start with this. I looked through the stickys and read the earshave procedure but I was wondering if there is a thread that has instructions for coastering showing all the pieces that can be taken out/off when doing the procedure?
Any help is appreciated, thanks!
C_Wage is offline
post #2 of 3 (permalink) Old 03-29-2017, 02:23 PM
Alpha Geek
Hexadecimus's Avatar
In the first part diagram, you'll remove the reed valve covers, the reed valves themselves, and replace those with your coasters. Parts 11012a and 12021. With the thinner coasters, you may need shorter bolts to avoid bottoming them out in the holes. I grind them shorter. I've seen people snap them off in the heads from not doing this.
In the second diagram, you'll remove everything in the central outline. This leaves an unfiltered hole in your intake. Plug that. A good duct tape should last quite a while.
DO NOT leave the grommet in place! I just worked on a bike that had crazy carb problems after I did a meticulous rebuild on them. It had somehow sucked that grommet down the intake after a DPO coastered it. After I replaced the carbs, it made its way down further and propped one of the slides open. Could have gotten sucked down the intake and bent a valve if the throttle plate had been open further.
Hexadecimus is offline
post #3 of 3 (permalink) Old 03-29-2017, 02:24 PM
Alpha Geek
Retrying attachments..
ID:	36466   Click image for larger version
