Im not a quitter!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
post #1 of 26 (permalink) Old 02-02-2017, 08:05 AM Thread Starter
vulkan's Avatar
Im not a quitter!!
But damn for the life of me cant install that new choke cable!!Gotta get way up under the frame/breather assembly AND a tiny spot there between the carbs.Freakin got a lot "disassembled" (gas tank off,filter pods,ect,ect) then called it quits when I saw really no way to remove breather assembly 'cause its tight in the frame and wrapped around the engine.So the bullchit is guess I'm gonna do a "rig" on the broke cable.
Name:	Vulcan choke cable.jpg
ID:	35354   Click image for larger version
Name:	Vulcan breather.jpg
ID:	35362   Click image for larger version
Name:	Vulcan choke tight fit.jpg
ID:	35370   Click image for larger version
Name:	Vulcan tight mess.jpg
vulkan is offline
post #2 of 26 (permalink) Old 02-02-2017, 08:19 AM
NIBiker's Avatar
No don't do that, there's a PDF works manual on line, can't find the link just now, but here's a picture off it, what bit are you finding hard? Hardest (fiddly) bit is getting it hooked into the car and the outer elbow sits into a bracket on one of the carbs , the cable just feeds up through the frame along the side of the intake shroud! Patience!
Sent from my HTC One_M8 using Tapatalk
NIBiker is offline
post #3 of 26 (permalink) Old 02-02-2017, 08:20 AM
NIBiker's Avatar
Sorry the pic isint too clear but you can zoom!
NIBiker is offline
post #4 of 26 (permalink) Old 02-02-2017, 01:48 PM Thread Starter
vulkan's Avatar
Nice try but ....more help!
vulkan is offline
post #5 of 26 (permalink) Old 02-02-2017, 02:03 PM
NIBiker's Avatar
Think the manual download is on the forum somewhere I'm sure. I know it's a fiddly job, I had problems myself, thought all was fitted right but wasn't just right at the carbs, caused the choke to stick on, but I persevered and got sorted in the end! Good luck with it!
NIBiker is offline
post #6 of 26 (permalink) Old 02-02-2017, 02:09 PM
NIBiker's Avatar
Do these help any?
NIBiker is offline
post #7 of 26 (permalink) Old 02-02-2017, 02:13 PM
NIBiker's Avatar
Do these help any?
PS, the PDF manual is anouncements and stickies!
NIBiker is offline
post #8 of 26 (permalink) Old 02-02-2017, 02:41 PM
You mean this one?
https://www.vn750.com/forum/11-vn750-...-download.html
post #9 of 26 (permalink) Old 02-02-2017, 02:43 PM
NIBiker's Avatar
Yes that's the one!
NIBiker is offline
post #10 of 26 (permalink) Old 02-02-2017, 04:30 PM
jgs000's Avatar
Location: elmira ny, great place to ride, no jobs though
hang in there, spent hours trying to work on those carbs, If I have to do anything to those carbs now, I just rip all that stuff out of there and go to pods and remove the air box so I can see the carb when I take the tank off.
i've went to the dealer to see how much and if they have a problem taking off and putting on carbs, they do its about 500 dollars.
if the cable is all you got wrong see how much it is for them to put it on, let someone else try it, but if you are going to work on it in the future, I would take all that stuff out now while you got it apart. good luck
jgs000 is offline
