need help and input - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 11-02-2008, 05:26 AM Thread Starter
Concert connoisseur
wib714's Avatar
need help and input
just installed a mf battery a couple months ago but it doesn't seem like it still takes much to drain the bike at all. while riding yesterday to the bank it started cutting out like it was out of gas, switched to reserve and got to the bank and back fine and fueled up. went to leave work and the bike was dead. took to charger in to work and charged it to full while taking the kids trick or treating, the bike started fine and drove it home. got up to go to work the next day and went to sears and it starting cutting out again like it was out of gas switched to reserve again and tried to start it but it is dead again.
Does this sound like a fuel issue, a battery issue or if my stator was to far gone would it cause it to cut out like that went the juice was used up in the battery like it would in a car if the alternator is bad. thanks in advance for any suggestions, never fails after riding a couple weeks in 30 degree weather its suppose to be 75 all week and my ride is down. just my luck!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 12 (permalink) Old 11-02-2008, 08:40 AM
Crobins365's Avatar
I'm not sure if a dying stator will cause your bike to be fuel-starved, but it will definitely contribute to the battery drain (which seems like your biggest problem at the moment). It doesn't look (from your sig) like you have a voltmeter installed - have you tested the charging system at all? Just in the garage, starting the bike, and revving the engine to 2500+ rpm with a voltmeter on the battery? With a fully charged battery (12.8v) you should see a jump in voltage to 13.5-14.5v when the rpms are above 2500. If you're not seeing that, then you'll want to test the r/r (and hopefully that's the problem -easy fix).
For the fuel delivery issues, I'd bank on bad gas, crud in your carbs or a vent line that's out of position. When was the last time you put in a full tank of gas?
C
Crobins365 is offline
post #3 of 12 (permalink) Old 11-02-2008, 02:01 PM Thread Starter
Concert connoisseur
wib714's Avatar
I fill it up 2 - 3 times a week. it had at least a quarter tank when it did it first then I filled it up and added 2 oz of seafoam and it did it 25 miles later. havent tested the charging system yet but that will be first when I get it home.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 12 (permalink) Old 11-02-2008, 02:06 PM
Crobins365's Avatar
Darn, I was hoping you'd say, "Haven't put in a full tank for 2 months" or something. Rules out bad gas. And the Seafoam shoulda taken care of small bits o' crud. Definitely test the charging system and let us know what you find. 'Tis the season for engine pulls and stator installs.
C
post #5 of 12 (permalink) Old 11-02-2008, 02:18 PM Thread Starter
Concert connoisseur
wib714's Avatar
tis the season, it could have waited a couple more weeks, its 75 out here today. I've been riding in 35 degree for a couple weeks.
if it is the r/r or the stator any recommendations on where to get one. bike bandit want $311 for the stator and 100 for the r/r. I would consider a used r/r but think I would have to go new on the stator since it is so difficult to replace but 311 is pretty steep at the moment, anyplace out thee cheaper!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #6 of 12 (permalink) Old 11-02-2008, 02:35 PM
Crobins365's Avatar
Well after complaining about the Buy It Now prices on eBay, I did see a new stator on there for around $150. I've gotten mine as rebuilts, but maybe someone else can pipe in on where to get a cheaper new one??
C
post #7 of 12 (permalink) Old 11-02-2008, 05:15 PM
Now what
Ironman's Avatar
It's a long shot, but I'd check all the connections for tightness. A corroded ground cable can cause weird problems. There's a bullet connector in the white and red wire coming off the battery. Most of the current to and from the battery travels through that connector. I had a loose ground cable on the battery and it caused the bike to sputter, back fire and act like it was running out of gas. The stator is probably shot, but that costs a lot to replace (in money and time). Checking out connections is free. Good luck.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #8 of 12 (permalink) Old 11-02-2008, 06:31 PM
If the charging system checks out OK, I'd do like Ironman suggests and check all the connections. Might just be something simple.
Also, a sometimes typical sign the stator is shot is the headlight not working.
post #9 of 12 (permalink) Old 11-03-2008, 12:40 AM
I think price is not the only thing to take into consideration here. There was a link here within the past month where there was a stator for the vn750 that put out several amps more than OEM. Sorry but I don`t recall who it was. If or when I have to replace my stator I would pay a higher price to gain another 5-7 amps. Does anyone know who sells this stator?
post #10 of 12 (permalink) Old 11-03-2008, 05:42 PM
I have heard that the stock stators don't last that long. The aftermarket ones will last alittle longer from what I have been reading here. Just put in another stator myself 2 weeks ago. The PO had a Kaw one put in by the dealership, lasted 2 yrs. Here is a link to an aftermarket place that has a very good price on new stators and I think that they have r/r also.
https://regulatorrectifier.com/catalog/index.php
tprender is offline
