New to forum, help with jetting. - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #11 of 26 (permalink) Old 04-24-2017, 11:20 AM
ubertalldude's Avatar
all that kinda stuff used to happen on my bike until I pulled, cleaned, and rejetted the carbs to 42 pilots/142 mains
ubertalldude is offline
post #12 of 26 (permalink) Old 04-24-2017, 12:01 PM
I would get the air filters installed before trying too much carb work. The carbs don't work well with wide open intakes or the wrong pod filters installed.
There's evidence of sticky valves being somewhat common on this engine. Mine had an occasional left carb sneeze on warmup. With the sneeze came a single tap or click from the top end. I ran seafoam in the oil 300mi before oil change to try and clean the valve stems, after that, the sneeze has been gone. Being lean can also cause carb sneeze on acceleration, but the tick led me to think it was a sticky intake valve. It could sneeze just idling with the choke on, or as I rode in 2nd or 3rd gear before the engine warmed up.
Just getting it out and riding may be enough to loosen up the valve stems and stop the sneezing. Try to listen for a tap when you're seeing/hearing the pop/blue flame.
post #13 of 26 (permalink) Old 04-29-2017, 10:33 AM Thread Starter
Welp, I got the filters and all is installed good and tight, went ahead and purchased a motion pro carb tune tool, set the mixture screws 1.5 turns out, warmed it up and went ahead with the carb sync, as I'm tuning her up I get it just right and the fan kicks on, then the motor slowly dies, I thought it was from the fan blowing hot air into the air boxes, Nope! The right exhaust is just dripping fuel like no other, so Im assuming the float got stuck. Either way I've been chasing gremlins on this bike ever since I got it, keeps me sane, I think.
TalkinVulcan is offline
post #14 of 26 (permalink) Old 04-29-2017, 10:54 AM
Does sound like a stuck float, tapping on the carb bowl can usually unstick them if it's not due to trash.
If the bike still has the goat belly, the exhaust mixes there, so right muffler may not mean right cylinder.
post #15 of 26 (permalink) Old 04-29-2017, 11:11 AM Thread Starter
Nope, I bought the bike with Vance and Hines Cruzers already installed. Good point though
post #16 of 26 (permalink) Old 04-29-2017, 11:37 AM
Thats 'Mr' Jr Member
majdsaster's Avatar
Originally Posted by TalkinVulcan View Post
I've been chasing gremlins on this bike ever since I got it.
Ohoh, you need a bell
37K+ Miles
Relocated R&R
LED License Plate Bolts
Solar Panel Battery Charger
Relocated new Turn Signals to Taillight Housing.
Replaced original round, chrome rear view mirrors with black, squared mirrors
Avatar: George The 3rd
June 2006 - Sept 27, 2013
Current Ride: 2005 Kawasaki Vulcan 750
4th Ride: 1981 Kz1000 LTD (2008 - Storage)
3rd Ride: Wife (1999 - 2005)
2nd Ride: 1982 Kz1000 LTD (1983 - 2004)
1st Ride: 1977 Yamaha XS-650 (1981 - 1983)
majdsaster is offline
post #17 of 26 (permalink) Old 05-03-2017, 10:15 PM Thread Starter
Got everything together, filters on, adjusted the floats while the carbs were off, did a single fuel hose to a T fitting with an in line fuel filter. Was a bit hesitant to start but once she did she idled nicely and I could hear the front cylinder firing. Got her warm, cut her off and tried to restart and nothing but gunshots lol. The front cylinder likes to go bang a lot.
post #18 of 26 (permalink) Old 05-04-2017, 09:30 AM
the "sanity" on this forum is a different breed of sanity...
OleDirtyDoc likes this.
post #19 of 26 (permalink) Old 05-04-2017, 09:47 AM
it puts the lotion in the basket or else it gets the hose again.hahahahahahaha the fox will be surprised
ubertalldude likes this.
post #20 of 26 (permalink) Old 05-04-2017, 09:48 AM
do you have an agm battery?
