Am I missing a hose? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By Knifemaker
  • 1 Post By michiganteddybear
post #1 of 6 (permalink) Old 11-04-2016, 03:50 PM Thread Starter
Idk what that's for but there is a t fitting with no hose hooked to it and idk if there is suppose to be one there
Ajlong90 is offline
post #2 of 6 (permalink) Old 11-04-2016, 05:16 PM
Looks like the T that is part of the carb vent system. There should be a hose that goes into that and into the rear of the right airfilter box.
thtanner likes this.
post #3 of 6 (permalink) Old 11-04-2016, 06:50 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
The factory running of your missing hose, like KM says, goes into a spot in the back, rear of your right air filter box. There's a hole there that you just slide the hose through. Its put there so the open end of the hose can be in a "dead" air-space. A neat trick, that is highly suggested for you to do, is to trim that end of the hose at a slight angle so as to prevent an otherwise "flat" end from ever being able to wiggle over and bottom out up against the airbox and prevent any flow of air. The cut angle ensures that the hose is always open.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #4 of 6 (permalink) Old 11-05-2016, 12:00 PM Thread Starter
Do I have to have a hose there? Would not having one cause the bike to not run correctly?
Ajlong90 is offline
post #5 of 6 (permalink) Old 11-05-2016, 12:48 PM
It can, it will prevent proper venting of the fuel bowls, resulting in inconsistant levels of gas in the carbs. which in turn leads to crappy running
OleDirtyDoc likes this.
michiganteddybear is offline
post #6 of 6 (permalink) Old 11-05-2016, 03:03 PM
x2 on all the above
OleDirtyDoc is online now
