Air/mix screw plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By ClimbBikeBrett
  • 1 Post By Knifemaker
post #1 of 7 (permalink) Old 09-22-2016, 12:23 PM Thread Starter
ClimbBikeBrett's Avatar
Air/mix screw plugs
Hi,
So, I have some popping during deceleration, and want to adjust the air/mix screws to see if that helps. My question is, without a drill, how in hell do you remove the metal (lead?) plugs? The carbs are oriented in such a way that I can't get to the plugs straight on. I'm thinking I can lightly hammer in a screw to create a hole and then use a pick to pull the plug out? I just don't want to brake anything expensive, and if i hammer in at an angle that may put a lot of force to the back of the screw housing. I really don't want to pull the carbs, haha. This bike had been coastered with a black epoxy by the previous owner that looked like they were leaking air, so i recently bought and installed proper metal coasters. I also think I may have to replace the exhaust pipe crush gaskets (especially the right side as it is popping far more than the left and seems to be getting worse) and I will get the Harley gaskets and do that later this week. Thanks in advance for your advice!
Brett
ID:	34249   Click image for larger version
ClimbBikeBrett is offline
post #2 of 7 (permalink) Old 09-22-2016, 12:59 PM
Expendable newbie
evulcannibal's Avatar
The plug is kind of thick maybe around 1/8 inch I forgot. The angle is really weird and will be hard if you don't want to remove the carbs. Maybe you can use a small sharp screw to pierce the plug and then yank the screw out.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #3 of 7 (permalink) Old 09-22-2016, 01:06 PM
Hitting it with a hammer might drive the plug further in, and the edges of the hole are thin cast aluminum, which you can easily break.....
So be careful!
(You don't own an electric drill?)
post #4 of 7 (permalink) Old 09-22-2016, 02:06 PM Thread Starter
I don't own a drill, haha. I've never worked on any kind of machine before. I just asked a buddy if I he had one and he does, So I will use his ( very carefully). Since I'll be going in at an angle, I will drill a shallow hole, and then use a screw to pull it out. Hopefully that works!
thtanner likes this.
post #5 of 7 (permalink) Old 09-22-2016, 04:36 PM
Put a piece of tape or a tiny length from a straw, or something on the drill bit to make sure you don't drill in too far. The plug is like less than a 1/8 inch thick, and you don't eat to drill in any farther....
Paulywog likes this.
post #6 of 7 (permalink) Old 09-22-2016, 05:38 PM Thread Starter
Awesome! I'm going to do the air/mix screws and a carb back flush tomorrow. I'll let you guys know how it goes.
post #7 of 7 (permalink) Old 09-23-2016, 06:39 AM
In the pictures are the external air valves. Replace the diaphrams inside of each one. They could also be your problem.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
