drastic drop in mpg - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-09-2008, 05:15 PM Thread Starter
drastic drop in mpg
ok so i noticed that my fuel gage is getting low... like almost on E so i looked at my milege and its only at 80 something miles.... i thought maybe my fiancee turned the trip sometime but ive been the only one riding it since i filled her up.... the noly thing thats changed is the exhaust pipes that i put on her..... is there something else that im not thinking of that could cause that much of a drop out of nowhere?? im checking the air filters and hoses tonight to make sure im not leaking any gas anywhere .... i just did an oil change like 2 weeks ago and maybe have 50-100 miles on it since then.... kinda at a loss...
bigrepp61 is offline
post #2 of 4 (permalink) Old 10-09-2008, 05:49 PM
Calif Rider
weh44att's Avatar
You can pull you plugs and see what they look like. Black means they are burning way to rich. Then check your oil and see if it is to full, gas maybe in your oil and this is not good for the engine, thins out the oil. Keep checking you will find what is wrong. Next would be the carbs, floats may be sticking.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 4 (permalink) Old 10-09-2008, 05:52 PM
liljd's Avatar
Also check for any leaks in the lines or tank.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #4 of 4 (permalink) Old 10-09-2008, 06:14 PM Thread Starter
dont see any gas anywhere and dont smell any so i dont thnk thats the culprit... ill have to fill u sometime and check then..
