Fuel Bowl Plate - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 09-08-2016, 12:11 AM Thread Starter
mcinturff's Avatar
Fuel Bowl Plate
Hey guys, I just pulled the carbs off my 750 and in the process not only did my friend manage to break the plastic off the brass fuel inlet on the rear carb plate, but the front carb plate was broken (at the tab for one of the 3 bowl screws) and put together with jb weld by previous owner's mechanic. Any chance of replacing the plate?
My alternative is to kwik steel the broken aluminum for the bowl and drill then insert a brass fitting on the fuel inlet.
mcinturff is offline
post #2 of 2 (permalink) Old 09-27-2016, 12:19 AM Thread Starter
mcinturff's Avatar
Found a replacement set of carbs
Engineer/Motorcycle Junkie
Junction Box Bypass:
https://www.vn750.com/forum/19-electr...-problems.html
