marbling question?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 09-29-2008, 02:34 PM Thread Starter
marbling question??
OK...I know this has been covered quite abit here, but I can't seem to have any luck doing the marble job. I've looked back at other posts and can't figure what I'm doing wrong. I used two marbles (one in the front and one in the rear) and I plugged off the small line on the right side of the bike.
when i tried to run the bike, it would run on full or half choke, but with any throttle it would die. It wouldn't run at all without the choke
any ideas or pics would be appreciated
Tdevil76 is offline
post #2 of 5 (permalink) Old 09-29-2008, 02:56 PM
liljd's Avatar
Adjust your idle screw in a bit and see if it helps. I had to also adjust the fuel/air mix a bit leaner.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #3 of 5 (permalink) Old 09-29-2008, 03:35 PM
Chucklehead
dragon159's Avatar
The line on the right side isn't so much the concern, but the nipple on the carbs where it came off is. If you did what I think, that nipple has to be plugged/capped. Leaving it open would throw the mixture way lean causing you to have to choke severely to get it to run.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 5 (permalink) Old 09-29-2008, 03:53 PM
Scootergptx's Avatar
Kinda thinking along the same line, Dragon.
Took the seat off on mine and plugged the line from that end. So it still looks factory from the outside.
Global warming? So what if my kids never see a polar bear. I never saw a dinosaur and I'm ok.
Scootergptx is offline
post #5 of 5 (permalink) Old 09-30-2008, 12:30 AM
Benjammin'
BSkaggs513's Avatar
Tdevil,
Everything you ever wanted to know about popping on decel...
https://www.vn750.com/forum/showthread.php?t=1081
Good luck!
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
