Choke - Is It Working Or Not? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 7Likes
post #1 of 33 (permalink) Old 08-11-2016, 07:36 AM Thread Starter
rad4u2's Avatar
Hi,
I'm working on this 1993 Vulcan 750 that I purchased last week and noticed that when the bike is running, the choke does not seem to make any difference in the idle.
Can you please look at the YouTube video that I uploaded showing what is happening and help me figure out if the choke is just not working at all or if this is normal for it to not have any impact on the idle once the bike is running?
Thank you!
rad4u2 is offline
post #2 of 33 (permalink) Old 08-11-2016, 09:50 AM
well, thats seems to a lotta nuttin..
on mine, when I put choke on, I get a definate change in engine rpm/attitude (will even cause stumble/stall in right conditions).
check the cable, see if its moving the linkages on the carbs.
also, just as a reminder, its not a 'choke' (even tho they call it that), in an enrichening system. it does not have a choke plate on the bike, but instead opens up a couple passages in the carb to allow more fuel and air in at idle
rad4u2 likes this.
michiganteddybear is offline
post #3 of 33 (permalink) Old 08-11-2016, 10:37 AM
Check for cable movement, otherwise the ports in the carb may be dirty, or not opening.
It's idling 3k in this other video? Idle set too high then?
I've never tried it, but I wonder if having the idle that high can cancel out the choke?
https://www.vn750.com/forum/31-engine...e-running.html
rad4u2 likes this.
post #4 of 33 (permalink) Old 08-11-2016, 11:05 AM
Yes if idle is too high it won't idle up with choke
rad4u2 likes this.
post #5 of 33 (permalink) Old 08-11-2016, 01:40 PM
Maybe the choke is stuck on? (Thus the high idle and why it didn't change when you turn down the choke lever)
rad4u2 likes this.
post #6 of 33 (permalink) Old 08-11-2016, 02:03 PM
Yup i mentioned that in his other thread
rad4u2 likes this.
post #7 of 33 (permalink) Old 08-11-2016, 04:09 PM Thread Starter
rad4u2's Avatar
Starting Without & With Jumper Cables...
Hi,
Can anyone tell (other than the choke not working) why the bike will not start without jumping cables?
You can preview this video showing where we tried starting it without and with jumping cables:
Thank you!
rad4u2 is offline
post #8 of 33 (permalink) Old 08-11-2016, 04:28 PM
Dead battery?
post #9 of 33 (permalink) Old 08-11-2016, 04:30 PM Thread Starter
rad4u2's Avatar
Bike Not Starting
Hi,
Can anyone tell what might be the cause of the bike not starting by looking at this video? (apparently the choke does not work but the bike kicks over most of the time)
1993 Vulcan 750
Thank you!
rad4u2 is offline
post #10 of 33 (permalink) Old 08-11-2016, 04:33 PM Thread Starter
rad4u2's Avatar
Yeah, the battery is supposedly new from the person I purchase it from but apparently it must be dead because the jumper cables helps it start up fairly quickly in most attempts. Does the starter and everything else sound ok though?
Thank you!
rad4u2 is offline
Tags
cables , choke lever , jumper , starting , withoutk
