Need Carb Expert - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-25-2008, 08:47 PM Thread Starter
Once Banned
cegodsey's Avatar
Need Carb Expert
A few weeks ago, I was giving my daughter rides around our neighborhood at <15mph, and I was having trouble keeping the bike idling - I had to keep the choke on full. I put some Seafoam in the tank and let it sit overnight. The next day, it started right up, and after warming up, idled just fine. But now the problem has moved to whatever is responsible for keeping the throttle open when decelerating. When I let off the gas, the engine slowly decelerates with a lot of popping/burbling. What do I need to fix/unclog? I'm not looking to marble it, I'm just looking to get everything back running like it was. I imagine it is some kind of vacuum-controlled thingy on the carb.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #2 of 6 (permalink) Old 09-26-2008, 07:04 AM
Crobins365's Avatar
First check your system for a vacuum leak; failing anything there, I'd suggest pulling the carbs apart and giving them a thorough cleaning. The Seafoam may have loosened up some bit o' crud that's now affecting the float movement or the coasting enricher. Tear it down, pull the gaskets, hit the jets and related with carb cleaner, and then dry thoroughly (and quickly) with compressed air. When you reinstall, make sure you sync the carbs.
C
Crobins365 is offline
post #3 of 6 (permalink) Old 09-26-2008, 11:34 AM Thread Starter
Once Banned
cegodsey's Avatar
Eww..I was afraid you'd say that.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #4 of 6 (permalink) Old 09-26-2008, 01:22 PM
Crobins365's Avatar
After you've pulled 'em a few times, it's not so bad. I think I can do it in my sleep now.
C
post #5 of 6 (permalink) Old 09-26-2008, 04:27 PM
Sky Rider's Avatar
It's easier if you've got skinny fingers.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #6 of 6 (permalink) Old 09-26-2008, 09:12 PM
another thing to check is the idle adjustment knob. this was a prob on my bike for a little bit...I fixed it by adjusting the idle.
