patching a fuel tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 15 (permalink) Old 07-21-2016, 04:06 PM Thread Starter
I'm a rider
One1's Avatar
I have a fuel tank from a VN that has several tiny pinholes from rust. I was going to go get putty, but then I thought maybe a spray over the whole thing would seal all the little pinholes. Is there a spray I could get at an auto parts store that would do a good job?
What else do you recommend?
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #2 of 15 (permalink) Old 07-21-2016, 05:22 PM
Tinkerer
Gaz73's Avatar
I've used Petseal in the past, works really well
https://www.amazon.co.uk/Petseal-Ult.../dp/B006VB6E02
One1 likes this.
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #3 of 15 (permalink) Old 07-21-2016, 09:11 PM Thread Starter
I'm a rider
One1's Avatar
Thank ya, I'm hoping to find something I can get locally for time reasons, but if not I'll explore other options.
1981 KZ750
One1 is offline
post #4 of 15 (permalink) Old 07-22-2016, 01:25 AM
Por-15 works good but you have to make sure that there is ZERO rust inside the tank. Where there's any rust the liner won't stick and will cause all kinds of problems.
One1 likes this.
Rakillia is offline
post #5 of 15 (permalink) Old 07-22-2016, 01:40 AM Thread Starter
I'm a rider
One1's Avatar
I can't eliminate the factors on the inside, but I can do anything I want to the outside. This is all underneath on the belly of the tank.
1981 KZ750
One1 is offline
post #6 of 15 (permalink) Old 07-22-2016, 11:39 AM
Expendable newbie
evulcannibal's Avatar
Duct tape to the rescue. No? How about some gum.
Okay for reals this time. You can try welding it or soldering it. Or try using those epoxy that are meant to seal radiator. Also there are some fuel tank repair kits.
Something like this
Permatex 12020 Gas Tank Repair Patch | eBay
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #7 of 15 (permalink) Old 07-22-2016, 12:39 PM Thread Starter
I'm a rider
One1's Avatar
I have a welder just trying not to blow myself up. Guess I'll fill it with water or something.
1981 KZ750
One1 is offline
post #8 of 15 (permalink) Old 07-22-2016, 02:07 PM
If you have pinholes, you have rust. If you don't take care of the rust whatever you do will just be a bandaid. You'll have to sand off the paint to see how bad it is on the outside and choose one of the many options to get rid of the rust on the inside. I've had good results with plumbers solder. I did try to braze a tank once. I forgot that particular tank was double walled and the ball of flames that went off made me think twice. If you fill it with water, you'll never get it up to temp without turning the water into steam.
OleDirtyDoc likes this.
Rakillia is offline
post #9 of 15 (permalink) Old 07-22-2016, 05:57 PM
Something like this
This. Sealed a large crack in a dented tank with it and it never leaked. (Wasn't pretty, but did the job)
post #10 of 15 (permalink) Old 07-22-2016, 07:07 PM
2000 VN 750 Senior Member
No matter what you use, the inside has to free of rust or there will be rust in the carbs very soon. It is just a fact. Fuel goes inside the tank and mixes with the rust and flows to the carbs. The fuel will loosen the rust so it makes it to the carbs for sure. I advise against anything that does not address the problem inside the tank. right now your tank leaks and soon you will have a tank that messes the carbs. That is a bigger problem.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
