Spark Plug Upgrade - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 09-15-2008, 11:04 AM Thread Starter
ExNewbie..Still Learnin'!
rsawyer's Avatar
Spark Plug Upgrade
Finally got off my butt and upgraded my plugs to the NGK Iridiums this past weekend. 10 minute job including verifying the gap on each plug. Could be just the "placebo effect" but seems to start easier and run better to me.
One issue I found though was that someone (shop?, PO?) had cross-threaded my right front cylinder when the plugs were changed last. I threaded the new one in very carefully and it seems to be fine, although it did feel a little like I was "rethreading" back to the original thread pattern.
Question is: How concerned should I be about the plug eventually stripping out of the cylinder wall? Once cross-threaded, how much damage has been done or are the cylinder threads "tougher" than the plug threads?
Any advice appreciated!
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #2 of 2 (permalink) Old 09-15-2008, 12:42 PM
If it doesn't hold, there are thread inserts that you can install that work fine. I think they are called 'Heli-coils'. You rethread the hole, clean it, glue up the helicoil insert and thread it in. Let it set up and good as new. Not too challenging a task if you can twist some wrenches. Years ago (decades, really) I did this to some aluminium heads on sports cars I was working on, worked fine. I wouldn't go that route unless you have too, but it is possible if you need to. Good luck
waterdog is offline
