Ok, turning the mix screw worked, but why? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 09-14-2008, 08:21 PM Thread Starter
PoggiPj's Avatar
Send a message via AIM to PoggiPj
Question Ok, turning the mix screw worked, but why?
The popping stopped for me at about 2 .5 turns. But if the problem is unburnt fuel making it's way to the pipes, then why does turning the screw out (CCW), and adding fuel to the mixture make it stop?
I would have thought that to stop the popping would have required reducing the amount of fuel to the mix... not increasing it. Can anyone explain what's actually happening in there?
Regards,
Pete in Gaithersburg, MD
1996, 6,000 miles
Relocated R/R, Corbin seat, Plexifairing III, Sunpro Voltmeter, Sears MF.
Xelement X840 Saddlebags
PoggiPj is offline
post #2 of 2 (permalink) Old 09-14-2008, 10:36 PM
Looking at your other post, you mention you blocked the reed valves. This is what made the difference, not just turning the air screw.
